Question about Kitchen Ranges
I have a 2610 wonderfire propane stove. The burner plate need to be replaced. It's cracked. Where can I find a burner plate. serial # 1827 . Thanks Lin
2 Suggested Answers
SOURCE: I need tips on installing a new burner plate and
I have a Wonderfire gas stove and it's easy to replace the burner plate and gasket. Hardest thing is getting the bolts out. Use a vise grips and you won't strip them. I don't use any adhesive on the gasket just clean everything off and replace.
Posted on Nov 05, 2010
Can I buy a replacement grill?
You could try Coleman, they might be able to supply one.
The Coleman Company, Inc.
3600 North Hydraulic
Wichita, KS 67219
1-800-835-3278
TDD:316-832-8707
Jul 03, 2014 | Coleman Vintage Bernzomatic Deluxe Propane...
Primary burner won't light on electronic button propane stove
If it won't light with a match,then the orifice is plugged.If it will light with a match because you can hear the gas coming out,then your striker on the knob is bad.It's replaceable.
Apr 14, 2014 | Coleman 2 Burner Propane Stove 5430E700
Coleman 5423b701
Try Coleman directly.
Wichita, KS 67219
1-800-835-3278
Sep 01, 2013 | Coleman Camping Stove 2 Burner Propane W/...
How do you convert a coleman 425e into a propane stove
Is there a reason or a need? I cannot imagine why you would want to, except as a point of interest for your camp kitchen. A new propane stove would work better and not cost all that much, relative to the work and cost of putting fittings, pipes and burners into the old stove box.
Feb 07, 2013 | Coleman 425e 2 Burner Vintage Used Camping...
I need tips on installing a new burner plate and gasket on a Wonderfire 2610 gas heater
Oct 08, 2010 | Heating & Cooling
Magic Chef propane in 90 Terry 5th Wheel
unfortunately the model plate for these
was usually mounted on the the drop wall
or were paper on the inside right corner
Oct 05, 2009 | Cooktops
Magic Chef Range in camp trailer, pilot light in the oven works however, the burner will not light when turned on. No gas flows. Propane furnace works ok and the propane bottle is full. The surface burners...
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
or
May be the ignitor, replaced mine and it fixed it. A gas company guy told me that is common in Magic Chef ranges.
Thanks for contacting Fixya
Jun 14, 2009 | Tappan MGF500PBW Gas Kitchen Range
STOVE TOP CONTINUOSLY SPARKS
Thrasher, Sorry I cant help with the diagram but one of your burner switches is grounding out. Each burner valve has a switch and one of them is finding it's way to ground, therefor the contstant clicking. Good luck on this deal...Catriver..post back.
Sep 06, 2006 | Garland H283 Gas Kitchen Range
Kitchen Ranges Logo
50 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
