Question about Roper Washing Machines
My roper top load machine is leaking after clothes are removed from machine...why is this
  • 33 Answers
SOURCE: Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Posted on Dec 17, 2008
  • 5911 Answers
SOURCE: roper top loading washer RTW444OVQ leaking when
You will need to remove the washer exterior cabinet in order to sufficiently locate the source of your leak. The following steps explain how:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
The pump and drain hoses connections are located in the FRONT of the washer directly under the wash tub.
The water inlet and dispenser hoses are located along the back.
To get the cabinet back on the washer, follow these steps:
1, With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
Some other things to consider:
1. Check your fill hoses to ensure they are tight and not leaking. What can often appear as a washer problem, may be a loose hose.
2. With the washer case removed, check the are UNDER the wash tub. If the leak is coming from the center above the transmission, the tub seal may be leaking.
3. Inspect the wash tub for any cracks. If the tub is cracked and its not serious, you may be able to get by with some marine epoxy to reseal it. If the crack is significant, a new tub will be required.
4. Check the air dome on the lower right hand side of the wash tub. This is a small plastic air hose that runs from the wash tub all the way to the pressure switch. If this hose comes loose, the washer will start to leak as it fills. Simply reattach if it comes loose.
NOTE: It is important to remove the washer case in matters like this so that you can get a full view of everything to determine the source of the leak. Read through everything thoroughly before beginning any repairs. I hope this information is helpful.
Posted on Aug 21, 2009
  • 401 Answers
SOURCE: Kenmore top loading washing machine does not clean clothes well.
I would seriously consider getting a newer machine. A brown stain could be rust, or an oil leak. Either way it probably is not worth putting any money into. If this helps, please rate my answer. Thank you.
Posted on Jan 07, 2010
  • 3085 Answers
SOURCE: agitator not moving like it should
Pull off the softener cup
remove the small cap
unscrew the bolt
remove top half of agitator
replace the plastic DOGS
Posted on Feb 07, 2010
  • 77 Answers
SOURCE: I have a Roper top load washing machine and the
the washer needs to have the lid closed to go into spin cycle the lid switch is broken just replace it and that will fix it
Posted on Apr 03, 2010
My roper wash machine is leaking. is it worth
check when it's leaking during the cycle.
If the fill hose has become unhooked from the outer drum of the machine, it'll just dump water all over the floor... it'll leak out of the case of the machine, but it's an easy fix... you simply open the machine, reinstall the hose into the drum or you may have to replace the hose...washing machines will last a good long's worth the trouble to fix...let me know if you need help opening it up.
This can happen if the machine is overloaded... I had a laundromat and this happened alot because people were cheeeeep and wanted to overstuff the machine thinking they'd get a better deal...not true...dirtier clothes and broken machines....
Aug 05, 2009 | Roper RAB2121KW Top Load Washer
Model RTW4340SQ0 clothes waster leaves oil-type stains on clothes
Remove agitator cap. Remove bolt underneath. lift off upper agitator and lower. Look for grease under agitator and on splined shaft and clean. Re-assemble be sure to put plastic thrust piece in between upper and lower agitator.
Jun 13, 2009 | Roper RAX4233PQ Top Load Washer
I am trying to get access to the top front of machine to check where water is leaking. Roper top loading washing machine
this video will help you how to remove your top front washer mishine.
Thank you
Yourratting is very important for me
Was this helpful?
Mar 21, 2009 | Roper RAS6233KQ Top Load Washer
Roper washing machine fail to remove enough water from clothes on spin
I had the same problem, I found that my discharge hose was partially plugged and when the water level get down to a certian point it would not drain,
Took me 3 days to figure it out........
Feb 19, 2009 | Roper RAS6233KQ Top Load Washer
My roper washing machine fails to remove enough water from clothes on last spin every thing else seems ok model RAS 7133 KQ 1
Possibly the centrifugal clutch is slipping, would need to be replaced, Go to appliance guru to see how this is done, they have step by step on this procedure.
Whirlpool "Roper" top-loading washer leaking
two screws hold back control panel on. panel flips up. two clips hold case on. remove clips and lid switch plug and whole outer case will tilt forward off machine base. pump is down in front and can be bought separate.
Apr 14, 2017 | Roper RAX4233PQ Top Load Washer
I have a Whirlpool top-loading "Roper" washing machine. It has developed a small leak under the front of it. I'd like to be able to remove the top of the washer and examine the outter wash tub to...
you can remove the top by prying at the joint with a putty knife.  The leak will most likely be in the back which is removed with the extraction of a few screws.
Jan 31, 2009 | Roper RAX4233PQ Top Load Washer
Agitator not spining properly to pull clothes down into water
remove agitator cap remove boplastic cover underneath remove bolt remove upper portion of agitator replace agitator dogs part # 80040
Jun 06, 2008 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
