How to reset service call m2 - Office Equipment & Supplies
    Master:
  • Office Equip... Master
  • 923 Answers
As a temporary fix, pull the fuse out (if any), or disconnect the connector under the affected seat. If it's a power seat, adjust it to the desired position, then disconnect the connector. You may have a failed switch or relay causing the problem.
Posted on Apr 29, 2017
What is solution for konicaminolta 164 maitanance call m2
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.
1-Press utility button on panel.
2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.
3-its the code to get into service mode.
4-After pressing above mentioned buttons you will enter into service mode.
5-Now select service choice option.select it by pressing OK button.
6-In service choice option you will see Maintenance count option.
7-Select it by pressing Yes or OK button.
8-There will be three options 0,1,2.
9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
Jul 04, 2014 | Konica Minolta bizhub Office Equipment &...
Code m2
menu,quick setting,<<quick setting <> and go to service choise ,maintenanc 0 press sit down go to clear data and clear maintenanc and supplies
May 16, 2014 | Konica Minolta Office Equipment & Supplies
Konika minolta bizhub 215 error code m2
You need to go into the service mode and then reset the supplies life counter.
Feb 02, 2014 | Konica Minolta Office Equipment & Supplies
CAUTION MAINTENANCE CALL (M2) CALL SERVICE
Replace the developer and drum/cleaning blade. Also reset the counters after replacing parts then run F8. resetting the counter with out replacing the above items cause image problems. The copier uses the counters to determine voltages on the drum you tell the copier drum is new and it is still old will cause problems.
Sep 18, 2013 | Minolta bizhub 180 Black and White Copier
Code m2 erreur minolta 5000
M2 mean s to remove the Waste Toner box in the back of the machine. Replace with a new one and reset the counter in service mode.
Nov 27, 2012 | Minolta EP4000/5000 CS/PRO Copier
M2 error service maintenance
m2 for km 163 or 7216 or equivlent models - it reaches alredy the copy life of the mchine consumbles like drum nd developer, you hve to replce it nd reset the progrms
Oct 05, 2011 | Office Equipment & Supplies
Maintenance M2 call service
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.1-Press utility button on panel.2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.3-its the code to get into service mode.4-After pressing above mentioned buttons you will enter into service mode.5-Now select service choice option.select it by pressing OK button.6-In service choice option you will see Maintenance count option.7-Select it by pressing Yes or OK button.8-There will be three options 0,1,2.9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
Dec 17, 2010 | Minolta bizhub 180 Black and White Copier
Konica Minolta bizhub 210 error m2 appear on display
Hi
You can reset (M2) by reset clear data
Enter to service mode By Pressing :
Utility - clear -0 - 0 - clear -0 - 1
Press ADJUST
Press CLEAR DATA
Turn OFF Copier and Switch it ON
Feb 28, 2010 | Konica Minolta Office Equipment & Supplies
Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
23 people viewed this question
k24674
jasbo
jasbo
