Question about Inverter Heating & Cooling
What MCB size should I use in 1.5 Ton Inverter Split Air Conditioner (AC)? 8.3A and 1.82kW written, should I use 10amps or 16amps or 20amps MCB rating to protect outdoor machine overload?????
  • 1,656 Answers
On the outdoor unit data plate will tell you max circuit breaker rating. This is what you need.
Posted on Apr 29, 2017
Testimonial: "But, my local electricians and AC Technician advising me to use 16A or 20A MCB instead of using 10A MCB"
  • Thomas Woodburn
    Thomas Woodburn May 01, 2017
    I'm having a hard time reading that but I believe that says max fuse??? I would put the 10, don't know why they would tell you that, or how it would pass inspection.
SOURCE: How can I get Westpoint air conditioner wireless remote controls?
Do you mean thermostat, the wireless controller for air conditioner? we are exporter of this line from China. Should you be interested in our products. Please feel free contact me at or add my MSN Our website is
Thank you!
Lee Lee
Posted on Oct 20, 2008
SOURCE: Voltage Stabilizer for LG 1.5 ton window type ac
4KVA capacity stabilizer is sufficient for 1.5 Tonne AC.
Posted on Apr 14, 2010
  • 43501 Answers
SOURCE: Wiring standard for Split AC 1.5 Ton
The factor that you have not included here is the distance from the power panel to the unit...if it is too far then you need to up gauge the wire to compensate for that... that could be why the electrician wanted to go to the 720 ga. wire.
Posted on Apr 16, 2010
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
SOURCE: Whirlpool Mastermind chrome 1 ton split ac, newly
how to use blower
Posted on Jan 11, 2011
User manual. Where can I get a copy
Pioneer Mini Split AC - Wholesale Prices, Open to Public‎ & Support
Download Manuals, Parts Diagrams
Sales, Technical Brochures & More
Nov 08, 2015 | Pioneer Ductless Mini Split INVERTER Air...
R22= 70-80psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Apr 21, 2010 | Dometic Rooftop RV Air Conditioner
Apr 16, 2010 | Samsung AS18A6RB Air Conditioner
My 1.5 ton,LG split AC shuts off rather
First the foam insulation is not just for looks,you will have some loss of cooling on the unit,the larger cooper line needs to be insulated,the small one does not.The large line is the suction line,the small one the liquid line.
Voltage,168 is low,sounds like a 208 volt unit or 220 volt.running at 168 or 198 ac volts is going to raise the amperage causing the compressor to run hot and work harder and soon burn up,And cause it to trip the breaker or shut itsself down on high heat.Your going to need to get that voltage fixed.I dont know why it needs a stabilizer if the unit was sized correctly it shouldnt need one.
Hope this helps.
Apr 14, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
Split ac runs for 2 hrs and MCB TRIPS
The most common reason is that the electrical power is not supply to the air conditioners. If the air conditioner operate for period of time then only it trips. Then , it could be possible that the MCB is under-sized. Please check the recommended MCB size.
Rate it.
Mar 02, 2010 | Heating & Cooling
Split ac not cooling the temparature remains at 27 degree after ac runs for about 4 hours.please solve this
Gas has leaked from inner or outer unit kindly get it checked by service men they will find the leak and charge the gas again normally after some time it gets rusty inside as water is involved and got leak
no problem get it repaired not expensive
pls rate me well !
Jul 14, 2009 | LG LS092CE Split System Air Conditioner
Could I use wire size 14 for 1 1/2 ton air window
No sir,14 gauge,three conductor will carry only up to 15 amps,which is usually wired for lighting circuits.Look on the electrical requirement plate on the unit,usually located under the front panel cover.It will tell you how many amps are drawn when unit is operating.Using a three conductor cable;wire accordingly:#14--15amps----#12--20amps---#10--30amps----#8--50amps.These are the wire sizes and the current(amps)they will carry.Be safe! Gregg
Jun 11, 2009 | Heating & Cooling
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
71 people viewed this question
Top Inverter Heating & Cooling Experts
Are you an Inverter Heating and Cooling Expert? Answer questions, earn points and help others
