Question about Cell Phones
My phone battery does not hold its charge for a day what can I do to fix this
  • 14,417 Answers
TRY REMOVING THE BATTERY AND THEN REINSTALLING IT AND SEE IF IT WILL HOLD A CHARGE,COULD HAVE A LOOSE CONNECTION OR BATTERY IS BAD.IF PHONE IS FAIRLY NEW,TAKE BACK AND THEY SHOULD GIVE YOU ANOTHER PHONE.
Posted on Apr 29, 2017
Phone will not charge, there is 5 or six blinks then nothing when plugged in. I ordered a new battery, but I hope the place where you plug in the charger isn't loose.
Try plugging the device in for a couple minutes then hold down the power button to see if it will power up, sometimes when the device completely drains it can cause issues with the battery that can be fixed once the device can get started again.
Dec 25, 2017 | HTC G2 Cell Phone
MY FREEFORM HAS PROBLEMS HOLDING A CHARGE, SOMETIMES IT SAYS LOW BATTERY AFTER ITS BEEN CHARGING ALL DAY. I TRIED USING ALL DIFFERENT KINDS OF CHARGES(HOUSE, CAR, ETC) DOESNT MATTER, BRAND NEW BATTERY SO...
It could be that your charger port is loose and needs to be fixed, which is a minor cost, and if you have a warranty on your phone they will fix it for you for free as long as it has no water damage. Good luck!
Nov 06, 2010 | Samsung Cell Phones
Battery won't hold charge
The reason your phone is not holding a charge is simply because there is a problem with the terminal head.
The terminal head is malfunctioning and is not charging the battery.
To fix the terminal head,
  1. After removing your back cover and battery, remove the screws you see.
  2. With the screws removed you can now remove the battery compartment.
  3. With the battery slot removed you have access to the terminal head.
  4. it is the metallic sheets that rests on the head of the battery when inserted into the phone.
  5. Get a pin tip soldering iron and disconnect the terminal head from the green panel you will see,
  6. replace it with a new terminal head.
  7. Reverse the whole procedure for reassembly.
Another fault might be the charger or the charging port,
To test if it is the charger,
Try to use the same charger on another phone to see if it will work,
If it does not work then it is the charger.
To test if it is the charging port,
Test a well tested okay charger on the phone to see if it will work.
If it does not then the problem is the charging port and to change it
you follow the procedure of of changing the terminal but you have to disconnect the screen and the remove the charging port and replace it with another new one.
take care
Jun 19, 2010 | LG VX8350 Cellular Phone
My samsung eternity is not holding a charge
it's either a bad battery or dirty/bad connections on the phone. i would say battery.
Jul 29, 2009 | Samsung Eternity Cell Phone
I had water spilled on my phone, and that day the screen went white and stopped working, then it fixed itself, but now it makes a weird cracking sound in the earpeice, and when it charges, and also it...
You would be better served to get a new phone. Getting a cell phone wet is almost alway death to the electronics. Even if the phone dry out completely, The problems caused by the damp electronics will cause strange and intermittent problems.
Jul 14, 2009 | Samsung Cell Phones
Holding a charge
Their website says only 6 hours of talk time for that battery. Could be that's all your gonna get from it. Every phone I've ever owned has needed to be recharged every other day and sooner if it's used more.
Dec 22, 2008 | Motorola Mobility RAZR V3t Cellular Phone
Battery not holding charge
That sounds like typical battery life for that phone.  When I owned one that's what I got on the weekends when my call volume was lower.
Dec 15, 2008 | Motorola Mobility RAZR V3
Water damage
it can be fix but i am thinking thta if you took to long for it to be fix but nevertheless take the phone to a mobile service center and have them service the phone to see if they can fix the issue.
Mar 31, 2008 | Motorola Mobility RAZR V3
Motorla Slvr L7 Won't hold charge
It depends on how much talking your doing. The Slvr is known for its low talk-time battery power. My slvr would last about 3 to 4 days on a charge, unless i was talking on it a lot. sometimes i would be charging it every other day. So it really all depends on the talk-time. Invest in a car charger for sure.
Dec 24, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Cell Phones Logo
37 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
