Question about Sharp Office Equipment & Supplies
I have sharp ar-5316e indicator massage error ink.drum. toner
    Problem Solver:
  • 15 Answers
Toner indicator says that there is low toner in the machine. It is necessary to replace toner cartridge and then continue with other error messages.
Posted on May 05, 2017
Bubbabear64
  • 2794 Answers
SOURCE: HELP, H4 ERROR
The fuser isn't heating up on time. You could try turning the copier off for 30 seconds and turing it back on again to see if it goes away.
If it doesn't happen, there is a part that has to be fixed on the fuser to correct the problem. Usually it is the thermistor.
Posted on Aug 17, 2008
  • 3 Answers
SOURCE: a new sharp ar 5316e photocopy machine photocopy blank
change the main charger because based on my experienced it has an arching problem
Posted on May 23, 2009
tehnik_bdg
  • 91 Answers
SOURCE: h4 error for sharp ar-5316e
Try reset the code by pressing [#] [Interupt] [C] [Interuptr] [14] [COPY/START]
If error still exist, check the thermofuse and the heater lamp
Posted on Jun 23, 2009
  • 47 Answers
SOURCE: L4 Error on SHarp AR 5316E
did you try changng the toner?
Posted on Jun 02, 2010
  • 257 Answers
SOURCE: my sharp ar-5316e error code CH please help me
Hope you are fine, ch are in two forms steady one and the blinking ch.
Steady CH
This is associated with door switch for either front cover or side cover. Check that the front cover of the copier and the right side is well closed.
Blinking CH
This is associated with the toner cartridge or the developer unit not being sensed by the machine. Make sure that the developer unit is well locked in the machine. Pull out the toner cartridge and insert back with some force into the machine, it should clear this sign. If it does not, replace a new cartridge Sharp Ar016ft and you are done. Good luck.
Posted on Nov 23, 2010
SHARP AR 5520 keep displaying TONER INDICATOR ALARM MESSAGE whenever I switch on the copier. And even if there is toner, the message keep displaying. So what is the problem?
Dear
The ink cart. is dual component one is drum unit and other is toner unit. You may go to system information there consumable information which indicate the status of the both and according to that replace the chip of the respective cart.
Thanks.
Jan 12, 2015 | Sharp Office Equipment & Supplies
What does F2 means in a sharp AR-5316E
its toner chip problem. You need to replace the toner chip
Aug 02, 2011 | Sharp AR-5316 Advanced Digital Imager...
My sharp AR-5316E is displaying Error F2
An F2 indicates a problem with either the toner cartridge chip that tells the machine that the correct cartridge is inserted, or the developer housing chip is defective. I would believe changing the toner cartridge will eliminate the problem.
Aug 19, 2010 | Sharp AR-5316 Advanced Digital Imager...
I am using Sharp AR-5316E copier (It makes noise)
Yes, Toner waste sump over filled; 100%!!! To confirm it, remove Toner cart. & make copy; I found same problem in Toshiba eStudio161, which is Sharp AR163, 5015, 5020 & 5316(all are same)
Jan 04, 2010 | Sharp AR-5316 Advanced Digital Imager...
My AR-5316E copier is displaying this error code H and 4
Your heater lamp maybe busted.
Use the simulation 14 to cancel the error..
If nothing happens then you need to check your heater lamp.
Oct 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
I have sharp AR-5316E copier, the indicator is
it is the problem your copier fuser unite problem thermostater or heat roller is over temparature . You press # interrupt c inturrupt then 24 press print key 00 then machine is of after on is ok
Jul 13, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp copier ar-5316
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
Jan 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
35 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
