Question about Akai Televison & Video
Akai Model X2000SD how do I hook up the cables for sound? I can get sound through the speakers, but can't turn it up.
3 Suggested Answers
gopakumarg43
  • 74871 Answers
SOURCE: I have an Akai Model LCT37Z6TA. The speakers are apparently busted. I have other speakers that I'm trying to hook up but I can't get them to work either.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Sep 15, 2016
SOURCE: Akai Reel-to-Reel Tape Recorder Model X2000SD how do I hook up the cables for sound? I can get sound through the speakers, but can't turn it up.
Most reel to reel tape recorders have "line out" in the form of RCA phono jacks. These are designed to be connected to an external amplifier. Some unit, however also have an internal amplifier and will output to speaker jacks that should be clearly marked. If your unit has such jacks and you cannot control the sound, your amplifier must be bad. Keep in mind, on most recorders, there are no internal speakers or output amplifier and the volume controls on the front are for recording only.
Posted on Apr 30, 2017
Apr 29, 2017 | Akai Audio Players & Recorders
I can't get sound on my akai tv. Picture comes on just fine. Just hooking it up to my DVD player. Please help!
speakers might be blown? buy some computer speakers and use the headphone jack
Apr 12, 2017 | Akai Televison & Video
My sound is out
SPEAKERS TURNED off (see set menu)
Internal/external switch for speakers in wrong position
Sound muted either on set or a BOX or volume turned way down on either.
Audio menu set to SAP or similar.
If you have sound with a DVD etc connected to rear audio/video inputs set has something set wrong and it is not likely the set causing this.
Akai is really Samsung (they own the name).
failing all above you may have a audio circuit failure but 90% of the time it is a setting in the box or TV or a hook up issue.
Apr 10, 2012 | Akai Televison & Video
My akai lcd tv model lct2721ad sound will not work.
We need to verify if the problem is in the preamp or poweramp sections. Hook up the powered PC speakers to the AUDIO Line out RCA jacks and verify that sound is OK there, if it is OK, The problem will be in the power amp sections that drive the speakers. If it sounds bad at the RCA jacks, the problem will be in the sound processor board which mean the main board will have to be replaced, same if the power amp is bad.
Nov 06, 2009 | Akai LCT2715 27 in. LCD Television
Do i need studio monitors so i can hear the sounds coming out of my mpc 4k?
you need some type of speakers either monitors that connect 1/4 inch cables left and right or you can use some speakers that hook up in the headphone jack but you are going to need an adapter to make the 1/8 inch to a 1/4
Oct 15, 2009 | Akai MPC-4000 Plus Production Center (w/80...
No sound
The speakers on these are usually at the bottom and do come off the set. If they are on the TV make sure there are wires connecting the speakers to the back of the TV at the speaker terminals.
Dec 28, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
My Brand New TV I got today 9-17-07
chek your output trasistor.hope this will help
Sep 18, 2007 | Akai LCT2060 Television
No audio
The speakers of the Akai is good so it is tempting to open it louder hence the chance of damaging higher. Try this to find out if your speakers are damaged....... raise the volume if no sounds, 1. remove the cable connection of the speakers from the TV whilst still connected to the speakers. 2.use a 1.5v battery to bridge the free ends of the disconnected cables, if you can hear sound...scratchy sound then the speakers are not damaged then 3. Connect a new external speaker to the TV if still no sounds, post back a message
May 12, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
RCA Audio Out not working?
You don't say whether you're successfully getting sound out of your stereo or not. I'll assume for the moment you are. Still getting sound out the TV is perfectly normal - RCA plugs have no mechanism for automatically disconnecting the built in speakers (in this respect, they're different from a headphone socket). Solution should simply be to press the mute button on the TV remote - although this will silence the TV speakers, you wouldn't normally expect it to affect the RCA output (failing that, just turn the TV volume control right down). A.
Apr 21, 2007 | Akai LCT2701TD Television
Televison & Video Logo
27 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
