Question about Ariens Garden
My Ariens Zero Turn tractor has stopped sucking grass and leaves into the grass catcher bins. Not sure why.
SOURCE: Excessive Grass
the grass is too high, cut it 2 times first cut should be half then the second cut should be the normal level. just remember go the other way on the second cut.
Posted on Mar 16, 2009
youcandoit2
  • 11 Answers
SOURCE: Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Posted on Jul 17, 2009
  • 496 Answers
SOURCE: I have a Craftsman Lawn tractor. Blade leaves grass uncut.
Hi Tom,
Check your spindle shafts for loose play. If your bearings are worn out and sloppy, the belts pull the spindle to one side and an angle cut results... close cut grass at outer edge and high in center will leave this grass trail you are describing. I'd replace the bearings next year for sure.
I hope this helps... Good luck!
Posted on Oct 05, 2009
bbreton
  • 437 Answers
SOURCE: ariens zero turn will not start
Have you done a load test on the battery? It may be time for a new one 300CCA. Plus the solenoid may not be working right. you will know more because of lack of information or symptoms.
Good Day.
Posted on Nov 07, 2009
SOURCE: Toro 42
Your blades may be erroded on the edges? Or the center blade hub might be damaged or worn.
good time to inspect all the blades and spindles for wear or damage.
Posted on Jul 02, 2010
Grass catcher doesn't fit
Do you a plate to attack to back of tractor with 4 bolts.
Feb 04, 2014 | Husqvarna Tractor Bagger
How do I put a grass catcher on Model #247.288842?
if the hood does not have provision for a catcher connection , then it is something you will have to devise how to do
if it has the connections then get the catcher and connect it up
Jul 21, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Grass catcher
What I would do Wayne is contact Ariens through the web site or at their dealership and see if one may be placed on your mower. Each manufacturer has their own set up for grass catchers, so I have not seen one the fits all. If you don't get anywhere Wayne, think about buying a lawn sweeper that is attached the the rear of you mower. If you purchase a good one, you will be very happy with it's performance. I hope that helps you out in some manner.
Jun 18, 2013 | Ariens 42" Riding Lawn Mower Blade ...
Wierd grass catcher problem
There are a couple of causes for this. Is the blade height the same on the new mower? Higher blade height could cause a lot of the grass to be blown out from under the deck, and not into the catcher chute.
On the trailing edge of the mower blades is a small 'wing' for lack of a better term. There are two types of blades, mulching blades that have a lower 'wing', while catcher blades that have a slightly higher 'wing' but it makes a difference.
If the season has been hot lately, the grass may not be growing as fast, hence less clippings, and less dense grass could also cause this.
Jun 16, 2012 | Mtd Garden
My Ariens 34" zero turn's
there is a switch under the hand brake that you can by pass this is not a good idea but it works e-mail me when you get it whitejeff74@yahoo.com
Jul 19, 2011 | Garden
Garden Logo
21 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Are you an Ariens Garden Expert? Answer questions, earn points and help others
