Macbook is slow. I already cleaned it and it is still running slow, freezing, dropping tabs,
10 yrs old
  • 1486 Answers
SOURCE: pondmaster 1800 is slowing down pump is clean of
Change the brushes in the motor.If its running 24/7 then thats your problem.
Posted on Aug 01, 2009
  • 4070 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Posted on Jan 21, 2010
  • 1871 Answers
SOURCE: emachine running SLOW and Freezes - 1 year old
Here are some suggestions: First of all . Do you have an anti virus installed on your husband's machine ? Viruses can slow the machine and even kill it permanently ( so be careful) . Just install an anti virus and you'll solve the problem . If you are already have an anti virus , then just run a full system scan and watch what will happen and follow the recommended steps that will be given by the anti virus [ There are a lot of anti virus softwares in the market ] but if you suspect that your system is already infected i recommend you to use (Avast professional edition) because it can make a boot scan , that means after you install it , it will ask you if you want to make a boot scan , just agree with it and it will reboot the system and start a boot time scanning , meanwhile you should watch it and give it the right orders if it detected a virus infection . Here is another suggestion : There is a certain software you could install it . This software can help your machine and detect any problem on your husband's computer but viruses . this software is called (TuneUp utilities) . You can download it from here . just try it and you'll be satisfied with result . if that didn't help just contact me again and i'll help you as possible as i can .
good luck .
Posted on Jan 29, 2010
SOURCE: I have an Inglis stove around 10-15 yrs old. When
Yes you can but not the elements themselves
Posted on Apr 18, 2010
  • 50 Answers
SOURCE: Ice maker not working. refrigerator is freezing
if you have the settings correct then the cold control(ref setting) is bad. but some older models use a baffling system which confuse some people. the freezer settind turned to the lowest setting make you fridge colder. when you put the freezer on the highest setting it allows less airflow. which in turn keeps ref warmer.
Posted on Aug 01, 2010
How to fix a slow Mac? My MacBook is getting slow recently, how to speed up it?
there are many reasons about why your Mac works slowly. you should firstly clean it up. here is article which talks about how to speed a Mac you may need: 11 Methods to Speed up Your Mac
Jun 25, 2015 | Apple MacBook Air
Macbook pro running slow
Generally speaking, there are quite a lot of causes for a running slow or freezing MacBook, if you prefer a quicker yet easier way to fix the performance issues, see here:
Jun 11, 2012 | Computers & Internet
My computer freeze very often
There are quite a lot of causes for a running slow or freezing MacBook computer, if you prefer a quicker yet easier way to fix the performance issues, see here:
Dec 26, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My speed drop down
Well, there are quite a lot of causes for your running slow or freezing MacBook computer, if you prefer a quicker yet easier way to fix the performance issues, see here:
Jun 14, 2010 | Apple MacBook Pro PC Notebook
My freezer not getting cold. it is about 10 yrs old and after Hurricane Ike it stop freezing.
if the fan run and does not freeze, possible compressor or compressor start kit. Start kits that a beating in stormy weather. Start kits consist of a relay, capicator and overload sensor. These 3 parts can be ordered seperately or a generic start kit with all the of these made in one. if the compressor is bad on a 10 year old freezer you might want to look at a new freezer
Feb 28, 2010 | Kenmore 65802
BJC-85 Not printing. New BC-10 and BCI-10. Paper loads normally
The problem you are having is with the print head and not the printer. Unfortunately, with these canon print heads, they are not dated, so it is possible to install a print head that was bought new and sealed, but is still dried out because it is old.
Try running the print head through one deep cleaning cycle, this sometimes will start to get an old print head flowing.
Deep cleaning cycle can be found by going to PRINTERS , right clicking on the BJC icon, selecting PROPERTIES from the drop down menu, and then selecting the MAINTAINENCE tab.
Check to make sure that the ink tank in the print head isn't dry. Even a new print head can have a dry tank if it's old.
Jan 10, 2010 | Canon BJC-85 InkJet Printer
Not cooling or freezing, can hear the motor running and electricity to getting to it, but melted everything and hot inside. 10 year old side by side icemaker
Hello there..your problem seems to eminate from either a failed compressor...or an internal gas leak....the compressor may be running but unable to pressurise the system....however the most likley cause is an internal gas leak....generally not repairable at 10 yrs old i would advise replacement
regards Sir Galahad
Sep 21, 2009 | Refrigerators
My son has a 3 year old Craftsman lawnmower with a B&S 6.5HP engine. The engine sounds like it is running slow. It starts real easy and runs smooth but seems to be running slow. Looks like there's no...
There is a governor adjustment on it.Find the governor spring coming from the carburetor the link will lead to a governor spring hooked to a metal tab,by bending the metal tab it will pull the spring tighter making the engine run at a higher rpm
Aug 17, 2009 | Craftsman Garden
87 celica sitting for 10 yrs, will not start
You need to drain all old fuel out of the fuel tank, the fill with fresh fuel, clean or change filters (air and fuel)
and if possible blow fuel lines through with compressed air. Check the plugs are clean and gapped correctly, check the engine oil is ok.
Then use some easy start in the air filter to get it to fire up, after 10 yrs it will be difficult to start, but should be alright after a few runs.
I hope this helps
May 14, 2009 | 1987 Toyota MR2
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
