Question about Kenmore Dryers
Kenmore Elite installation guide of a new heating showing were wires plug into what different colors
ginko
  • 19396 Answers
SOURCE: no sound.
The first thing you need to do is doublechecking all the new wirings, it sounds like a contact.
Posted on Oct 24, 2008
  • 111 Answers
SOURCE: I am trying to wire
The wire color going to L1 should be black or red and white would be neutral
Posted on Dec 19, 2008
  • 86 Answers
SOURCE: Radio installation
Please follow diagram on this link for proper installation:
http://www.telusplanet.net/public/rayray/ToyotaWires.gif
Thanks.
Posted on Jan 03, 2009
localwonder
  • 6784 Answers
SOURCE: kenmore elite , no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jul 27, 2009
blueextc3221
  • 15935 Answers
SOURCE: 73952 / 73954 / 73956 Gas Dryer: my kenmore elite HE5 110.8772 is not heating. My...
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Error code EO 14 kenmore elite oven
Unfortunately, the EO 14 code indicates a communication problem between the touch pad and the electronic control unit (the brain of the range). The control unit thinks that the touch pad's wiring is not plugged in. This can be due to a problem with the wiring or the touch pad slowly failing. Before ordering parts, check if the wiring is secure on the connector. Then check the wiring for continuity. If those are fine, the touch pad is usually replaced next. If the new touch pad doesn't solve the problem, then try a new control panel.
You'll need to give the full model number (4 more digits) for the range if you want to get the correct part numbers that may be needed. I found one parts list for the 790.97502001 and the 790.97509001 here: ftp://ftp.electrolux-na.com/prodinfo_pdf/lassomption/5995602603.pdf . The difference between the models is their color; this results in different part numbers for the touch pad.
I hope this helps.
Jun 07, 2017 | Kenmore Kitchen Ranges
No sound.
Oct 24, 2008 | Kenwood KDC-MP338 Car CD Player
Light stays on even with door shut, kenmore he2 dryer
The door switch would be the first suspect... make sure the wires are in the proper sequence... does the light go off when you open the door? the tech sheet should tell you what color wires go to which terminals
Apr 27, 2016 | Kenmore Dryers
The ice guide for our kenmore elite side by side 106.56689501 was damaged. Do not know how to install the new part
Check youtube for icemaker install. They may not have the exact model but the video will show general install instructions.
Sep 19, 2013 | Computers & Internet
My Kenmore elite electric dryer will not heat. I
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Kenmore Elite HE4 Electric Dryer
Is it safe to use a 3 prong dryer cord on my 2004 Kenmore Calypso dryer? I moved to an older home with a 3prong outlet.
It is safe as long as it is wired correctly. The following link explains the differences between 3 and 4 prong configurations:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Just make sure to match the corresponsing wire colors at the terminal block in the back of the dryer:
RED - HOT (120 VAC)
BLACK - HOT (120 VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - Ground
In a 3 wire configuration the Neutral (White) and Ground (Green) wires are terminated together at the terminal block.
NOTE: If the wires are not color coded, the outer two wires (left and right) are the HOT leads. The center conductor is Neutral.
The other alternative is to have an electrician install a 4-wire receptacle in your home.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 31, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite , no heat
2. Heating element
3. Thermal fuse
Jul 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore HE4 Electric Dryer runs as soon as you plug it in, doesn't heat and display isn't lit
Make sure that the cord is installed correctly make sure that the white wire is in the middle of the red and black wires. Other than that it sounds like a Main computer issue.
Jan 16, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
