Question about LG Microwave Ovens
LG Microwave door will not stay open, while loading.
Lg microwave inside light stays on but microwave works fine. tried door swwitches
If the light is on without cooking, you have a faulty door switch.
Oct 26, 2017 | LG Microwave Ovens
Lg microwave above the stove, lt is level but door wont stay open,as your putting items in it starts to close ,is there any adjustment on the door
Only gravity keeps the door in open position. You can try to tilt front down by loosening the top mounting bolts.
Apr 29, 2017 | LG Microwave Ovens
My glass slides down and wont stay up on my LG microwave oven how do I repair that
Hello;
My name is Peter. I am a retired field service appliance technician.
I am not sure what you are talking about.
But here is a start to help you. Find the model number, which should be on the face of the microwave when you open the door or on the side of the door.
Take the model number and put in into the following website. You will get diagrams, part numbers and prices.
Get back to me with the model number and the part that is failing and I will help you further. Water Filters Lawn Garden Appliance Parts
Mar 27, 2016 | LG Microwave Ovens
My LG microwave will not shut off. When not in cooking mode and I close the door, the light stays on, it makes a light humming noise and the center plate continues turning
All microwave ovens have microswitches to confirm door open/closed. Many have several, and a bad switch can cause all sorts of strange issues. My ovens have 4 such switches, and I've had several go bad. You have to open the oven up to see which you need, measure them, and replace the bad ones. The good news is that the switches aren't expensive.
May 26, 2015 | LG Over-the-Range Microwave
Lg lmv2053 microwave oven baffle in between the glass and the door frame, how do i get it to stay so i can but the door back together????
To zig107 RE: LMV2053XX
A lot of times it's easier to set the microwave on its left side, then open the door and work on it.
That way, gravity will help you keep things in place.
On this over the range model, you'd have to pull the oven from the wall. Refer to your installation instruction booklet for details.
If for some reason you don't still have yours, you can order it as part number 3828W5U0492 from the Pros here. They are a good source for LG parts.
You can download the owner's manual here.
You can download the service manual by clicking the text link below the document preview on this page.
Be careful where you click on that page (which is not mine). Please follow the download instruction above.
Jan 21, 2014 | LG LMV2053 Microwave Oven
Samsung microwave #SMH1611B door won't close
If it has the "double hook" type latch on the door,see if the hooks slide up and down.They should be spring loaded,if not,the spring attachment point inside the door may have broken off(my Sharp Carousel did this).I pryed the plastic door trim loose,and reattached the spring by using one of the slots inside to hold a metal wire clip(modified with needle-nose pliers) to hook the spring onto.Your door's design may be a little different,but a similar solution will probably be apparent after you get in there.
Dec 18, 2012 | Microwave Ovens
Door button broken on LG LRM123 microwave
Many times a microwave will have a lever under the front edge of the unit to open it in case of a power failure. Have a look.
Helpful? Please Vote.
Mar 03, 2008 | LG LRM1230W Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
