Robot coupe R211XL ULTRA - Motor turns in the reverse. The capacitor has been changed and leads reversed The leads on the motor have been reversed , Both did not change the correct rotation.
  • ravi4259 May 01, 2017
    The motor used to turn in the right direction, but one morning decided to change direction when turned on.
    I thought AC motors couldn't change direction. Any help will be appreciated to fix this problem.
SOURCE: Minn Kota tolling motor
Reverse the polarity on the trolling motor by taking the trolling motor apart and turning ithe motor housingt 180 degrees and bolt it back up. The polarity will be straight then. I did the same thing when I pulled the armature back in.
Posted on Jan 09, 2008
robotcoupe
  • 3 Answers
SOURCE: robot coupe r 301 ultra
Remove the base the screws are under the rubber feet,on top of the machine there are three screw caps remove these with a bradel, unscrew screws with large torx screw driver, remove spindle anti clockwise by locking out fan at base. for all Robot coupe parts go to http://www.catering-machines.com/
Posted on Sep 11, 2008
SewTechWayne
  • 186 Answers
SOURCE: Juki MO-2516N motor runs in reverse
This machine as an AC motor which only runs in one direction no matter how the leads are attached.
Why do you need to reverse the motor direction?
Posted on Feb 01, 2009
  • 5495 Answers
SOURCE: 1996 ford explorer sunroof wont close
This website shows it has manuals and online diagrams like that. Sometimes a dealer parts guy will run you a copy of a parts diagram. It is a 13 year old vehicle- a salvage yard may have something torn apart that you could see.
Posted on Jun 10, 2009
  • 81 Answers
SOURCE: How do I assemble the Robot Coupe R 2 Ultra
Cindy,
Send me your e-mail & I will send you back an exploded view of your Robot-Coupe. It will give all the info needed. capt_rick1912@yahoo.com
Posted on Jul 25, 2009
Tip
How to Reverse the Rotation of Single Phase Capacitor-Start Electric Motors
Reversing the rotation of electric motors can be done easily with 3-phase motors. This can be easily achieved by swapping the connection of any two motor leads. But 3-phase motors are usually found and used for industrial purposes. The ones found and used in our homes, from water pumps to electric fans, are single phase capacitor-start type motors. Unlike 3-phase motors, reversing the rotation of single phase electric motors is no easy task. Swapping any two motor leads will not result in the reversal of the motor rotation. Analysis of the motor windings and connections are necessary before any modification can be done to achieve the desired result. Let's take a 3-speed single phase capacitor-start electric motor with electrical diagram shown below as an example. Make sure the motor is disconnected from the power supply before attempting to follow this tip. This tip is intended only for individuals with electrical knowledge, necessary tools, and understand the risks associated with handling electrical equipments and devices.
The first step in the process is determining the start winding which is connected to the line (AC white) and to one side of the start capacitor. To accurately determine the start winding, disconnect all motor leads from the start capacitor and the speed switch for multi-speed motors and then setting your ohmmeter to the lowest scale (R x 1), measure the resistances between the AC white line and each of the motor leads connecting to the start capacitor. The one with the least resistance is the starting winding lead.
Once the start winding lead going to the capacitor is determined, reconnect the capacitor then connect the black AC line to the found start winding lead (marked X). Connect the white AC line to L of speed switch, the motor lead formerly connected to AC white to 3, red to 2, and white to 1 as shown below. Leave the green/yellow ground wire connection as is.
Below are the wiring modifications for 2-speed and single speed single phase capacitor-start electric motors.
on Jan 11, 2011 | Dryers
Why doesn't drive shaft spin?
might be the start switch in the motor and or a capacitor. it should turn fairly freely by hand, if not it could be a bad bearing/bushing.
May 08, 2014 | Robot Coupe "R2 DICE - Combination Food...
Which way does motor turn
The motor is reversible by changing the wiring in the box on the side or the back of the motor...
Look on the label on the side to see which wire need to be changed to reverse the direction of the motor..
For many motors you will reverse the 5 and the 8 wire....on some you will reverse the red and the black.. on others there will be a different combo....
on three phase motors you can reverse any of the incoming leads to reverse it...
heatman101
Jan 19, 2011 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Blade not wrkong
I think they are all the retaining nuts are reverse thread
May 18, 2010 | Robot Coupe MP600 750 Watts Hand Mixer
Looking for spare parts for a Robot Coupe R301 Ultra Food Process
Robot-Coupe USA.com should be able to sell you anything needed
Jul 09, 2009 | Robot Coupe Food Processors
Fan motor capecitor
go to electric motor shop . take oem capacitor. replace with exact replacement. rule on capacitors is uf or mf rating must be exactly the same. voltage can be higher. for instance if you have a 370 cap you can replace it with a 440 cap but never the reverse. to pull a bad 120 cap and replace it with a 230 cap is ok. but to pull a 440 cap and replace it with a 230 cap is a no no.cap rating must remain the same . volt rating can be higher but not lower.if motor still turns in reverse look at the reversing leads. see wiring diagram on the side of the motor. most replacement motors can run cw or ccw. by switching the reversing leads you can effect direction. usually wired up orange to orange and purple to purple. switch org to pur and pur to org and motor runs opposite direction. be sure you have a new correct cap for the new motor. every new motor should have a new cap and they are different usually.one motor might be a 5 mf cap and the new motor might require a 15 cap! be sure power is off and you check it three ways. looks off, checks off with a meter, and is off when shorted with a screwdriver.good luck
Oct 17, 2008 | LG Electronic Window Air Conditioner
Robot coupe r 301 ultra
Jun 06, 2008 | Food Processors
Cindy,
Nov 02, 2007 | Robot Coupe R2U Ultra Food Processor
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
