Question about Grilling
I need the replacement burners but not sure what part # I need. Don't know what year I bought
    Top Expert:
  • 15,387 Answers
Use make and model number to order parts
Posted on Apr 29, 2017
Need all the six burners for this Magic Chef bought in an Army Surplus in the 40s. I don't know the Model because the Name Plate is long gone.
Try this place on EBay . http://www.ebay.com/itm/VINTAGE-STOVE-PARTS-Cast-Iron-Antique-Gas-Range-Top-Burner-Set-30s-40s-/160974704050?pt=Figurines&hash=item257ad70db2
Feb 16, 2013 | Camping, Backpacking & Hiking
Own a KitchenAid gas range superba, how do i clean the burner, one of my front burners the gas flow is very low, the stove has the glass/ceramic top with no wells & no way to get to the burners...only...
You'll need certified stove technician to service you kitchen Aid range. You have low gas flow on one of the burner. The manual gas control valve behind the knob needs to removed and cleaned. If you have one cleaned then have technician clear all four of these manual gas valves. While he cleaning the valve have do a complete check up of you Kitchen Aid range. Dangerous for the home owners to do this procedure because flowing natural gas or propane. In a lot the states you'll need to be certified by the state to work with natural gas, gas stove, ovens, gas home heating units, etc. It differentially a no,no here.
It is not the burners, it is gas flow valves for the burners. Most of the burner are made of aluminum and I wouldn't use any harsh cleaners of them. Check with Kitchen Aid and ask them what is recommend for cleaning the burners. Also the top of the range isn't ceramic but porcelain, it glass that has been melt to the top hood of the range. Don't use scratch pads, steel wool or any thing that will mare the Periclean surface of your stove.
If you can get the aluminum burner out to clean them then do so. GB you Allison and I wish you many year cooking on your Kitchen Aid range. stewbison
walk softly up on this earth and she will good to you...
Aug 21, 2011 | KitchenAid Kitchen Ranges
None of my igniters on my 30400043 Ducane grill will light the burners. I've had a grease fire due to the burners rusting out and replaced the burners. The insulation on the wires to the igniters has...
As I tell customers, when they ask me, "How long will this grill last?" "That depends on well you take care of it with routine maintenance and cleaning."
The wiring for the electronic ignition and the spark ignitors are replaceable. The ignitor button or the "clicker" as you called is replaceable. But all you may to do, is change the battery inside the igniter button. To help you further, i have included a link to the Owner's Manual for your grill. It will have an exploded view of the parts, which should help you identify them by part number and order them from Ducane, if you like.
http://help.weber.com/manuals/ducane/2008%20Manuals%20pdf/20529916_030308.pdf
A far as the infrared burners are concerned, they blow out easily if the wind is just blowing slightly. That's why they have a thermocouple on the burner, to turn the gas off to it, when it gets blown out. When preheating an infrared burner, the hood/lid of the grill should be closed.
I hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Ducane 30400040 Stainless Steel Grill
I have a caloric oven, prestige series. Don't know model. it is about 15 years old. last year the oven wouldn't heat and smelled gas. That was repaired. Now, oven ignitor comes on but oven...
The ignitor is bad again,if it (ignitor) comes on but no flame/heat its the ignotor again, what would make the ignotor go bad so fast (usually last 10-15 years) is a problem with the oven burner, so now BOTH the ignitor and burner would need to be replaced,if it is 15 years old the ignitor is readily avaliable but the burner may not be
Gene
Aug 04, 2011 | Ovens
My Blue Ember rotisserie only flames up and does not glow red. I have cleaned the ceramic tiles. what else can I do? Everett From Seekonk MA
Everett, it's not the ceramic plaques that are causing the problem, it's the burner that heats the plaques that's failed. Replacing the entire burner assembly is your only option.
It's interesting that you are still using that model Fiesta Gas Grill. It was recalled about 3 years ago.
http://bbq.about.com/b/2009/07/21/recall-alert-fiesta-blue-ember-gas-grill-2.htm but not for the problem you're having. If your model number is not mentioned in the link above. Don't worry about it.
You may be able to find a replacement burner from Fiesta or try Appliance Factory Parts
http://www.appliancefactoryparts.com/ Be sure to have the correct Model Number of your grill when looking for parts.
Hope this helped you. Please let me know and Happy Grilling!!
Jul 15, 2011 | Fiesta Blue Ember Gas Grill
Just bought a Charbroil 4637133 Quickset grill at yard sale and it clicks but doesn't ignite. I looked underneath and on the other side of the control panel there's a wire connected to the ignitor...
the wire is supposed to connect with a small round slip-on terminal lug. They often brake at the lug, so you are left with just a hanging wire.
Look inside the grill at the burner- somewhere you will find a small metal probe pointing towards the burner. Once you find the probe, look underneath for the other end. This is where the wire is supposed to go.
Good Luck, and Thank You for using FixYa!
Jun 10, 2011 | Char-Broil 7000 Quick Set Gas Grill
Steps in replacing 5 burners on Ducane burner mod 30400042
First calll Weber to get your replacement burners for free. There is a five year warranty on this model which is a little over 4 years old. I know this because I just received them from Weber for free.
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Jun 20, 2009 | Ducane 30400042 (LP)
GRILLPRO 45,000 BTU, HARDLY WILL RUN, NOT A LOT OF FLAME
The gas burner needs to be scrubed to open the holes again. The transfer bar that lights the outside burners needs to be cleaned also. Make sure the tank is not cold and there is plenty of gas. Make sure the valve is all the way open on the tank. Its not a regulator problem if one of the burner lights and the others don't. Usually if you barbacue a lot the sauce drips down an creats crud on the burners. Just use a wire brush on the burners. You may have to take them out to scrub them good.
Apr 30, 2009 | Brinkmann 810-2300-B Grill
APIRIL 28 2006 WE BOUGHT A JENN-AIR COOKTOP 30"BLACK STAINLESS STEEL. WITHIN THAT PERIOD WITH THE WARRENTY, AND EXTENDED WARRENTY I HAD TO HAVE THE LG DUAL BURNER REPLACED 5 TIMES THATS FIVE TIMES...EVERY...
THE STORE I BOUGHT IT AT HONORED THE IN STORE CREDIT AND REPLACED THE STOVE TOP.I HAD TO HAVE IT INSTALLED..BUT THAT DOESNT ANSWER MY QUESTION???? I WANT JENN AIR TO KNOW ABOUT THIS PROB INCASE IT HAPPENS AGAIN. HOW MANY TIMES DO YOU THINK THE STORE WILL REPLACE THE STOVE TOP WITH INFLATION THE WAY IT IS NOW.........TELL JENN AIR MY STORY PLEASE C TOP JEC9530ADS.....
Jan 09, 2009 | Kitchen Ranges
Grilling Logo
63 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
