Question about Food Processors
Food processor motor spinning in reverse - Food Processors
4 Suggested Answers
  • 10865 Answers
SOURCE: where can I buy repair parts for food processor
Call 1-800-851-8900 and order what you need directly from Hamilton Beach.
Please mark this as a fixya! thanks
Posted on Mar 18, 2009
  • 4088 Answers
SOURCE: When I turn on my cuisinart food processor, the
Either locked motor or bad brushes in the motor.
Posted on Jul 17, 2009
  • 44 Answers
SOURCE: hello there my food processor will not spin hear motor running lights on to go but no spin??
Post model no on line probably the rubber drive on the motor
they fall apart over time.found on line about 3or 4 dollars
Posted on Jun 19, 2015
Hello there my food processor will not spin hear motor running lights on to go but no spin??
Jun 19, 2015 | Kenmore Food Processors
Motor works but will not turn on
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl asssembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Jan 01, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart Food Processor Custom 14 turned off
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Dec 21, 2008 | Cuisinart DFP-14BC Custom Food Processor
Motor won't turn on
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. Make sure you enter your exact model# at Cuisinart's website, because a DLC-7 is not the same as a DLC-7E or 7P, for instance. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl assembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Nov 27, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
My food processor turn on button won't work.
-Tha Mp3 Doctor
Nov 25, 2008 | Cuisinart DLC-5 Food Processor
My brand new Cuisinart 14 cup food processor won't turn on. All the components are locked in place and it's plugged in. Help
-Tha Mp3 Doctor
Nov 23, 2008 | Cuisinart DLC-5 Food Processor
The cuisinart food processor doesn't work.
-Tha Mp3 Doctor
Aug 26, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart MP14 Will Not Turn On
If it no longer spins, the motor has a problem. (This one has a 20-year motor warranty)
-Tha Mp3 Doctor
Oct 30, 2007 | Cuisinart Limited Edition Metal MP14 Food...
Food Processors Logo
117 people viewed this question
Top Food Processors Experts
Ross Keen
Are you a Food Processor Expert? Answer questions, earn points and help others
