My unit stop working. Iturn power off and on the unit ran for 5 second blower didn,turn on. The only air option works and blower air. I check unit outside and was real hotyou
  • 1450 Answers
SOURCE: Blower not blowing
can you hear the fan working on all speeds?
Posted on Sep 22, 2008
  • 6 Answers
SOURCE: 2004 Yukon Denali
This is from the A/C Module located under the dash passenger side, check wether the internal fan is working if it is, then change the Module which is a small black part with two white metal blades like... and your A/C should work again...
Posted on Mar 21, 2009
  • 51 Answers
SOURCE: Intertherm Air Conditioner S3BA-042KA compressor and fan not working (has power)
It sounds like that unit is connected to a "power saving load controller" device from the power company. The power company can turn your unit on & off with a radio signal. If you manually activated contactor and unit ran. I would bet that the power company's device or the wiring connecting it is where the problem lies. Call the power company and have them check their device. If they tell you that the device has been tested remotely and is working fine. Explain to them that you can activate your unit manually and it works fine. They should not charge you to come out. Those "load controller devices" have a pretty good longevity record.
Posted on Jul 11, 2012
Testimonial: "Thank you. I was not aware that the power company had that ability. I will give them a call and ask about a test of their unit. Last year they sent me a postcard asking if I wanted to participate in their energy saving program. I declined but was not aware that they still had a device attached which could do it. I really hate surprises."
SOURCE: Vw polo heater blower only works on full power
all speeds go through the resistor except high that is why it will work on high you are bypassing the resistor if you are sure the resistor is good it has to be the blower spped switch on the dash
Posted on Sep 24, 2012
Testimonial: "Thanks for your help! Is there a way that I can check if the resistor is blown or not? There is no rust or loose connections. Or do I just have to buy a new one? Thanks again. "
  • 2101 Answers
SOURCE: I have a 2004 Chrysler Pacifica and the heater doesn't work. It blows only cold air or outside temp air out of vents when heater turned on. No matter how high Iturn the temp up.
your blend door motor is stuck or it may need to be replaced. the blend door controls the temp from heat to a/c
Posted on Nov 18, 2012
My unit stop working I turn power off and on the unit ran for obout 5 second blower didnt turn on The air only option works on thermastate and blower airI check unit outside and was real hot .
I don't understand. It sounds as if your outdoor fan is not running and is shutting down on thermal overload. Check capacitor in outdoor unit. Good Luck.
Apr 29, 2017 | Heating & Cooling
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
stops the operation.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
Carrier electric furnace (air handler) stopped running
The 5 amp fuse may be bad, they go quite often, and they are exactly the same as the car ones. Check the fuse with a meter. If its OK turn the unit on and check for voltage going to the blower fan. You should get a reading between at least one pair of wires. The unit should have a schematic on it somewhere, check it to see which wire pairs are used for the variable speeds of the fan.
Nov 08, 2014 | Heating & Cooling
Why does air conditioning unit stop after the second setting
Setting ? As in the speed of the blower ? If the speed of the blower is the problem check the resistor unit in the blower box unit probably under the hood. What year and engine size ?
Jul 29, 2014 | Dodge Dakota Cars & Trucks
Turnsignal switch, brake switch,windows, and heater blower stoped workingdodge electrical problems
air bag power runs off the same power line you may have a faulty air bag been may have burn't out the voltage control unit for the ignition. or the air bag has not been wire'd in properly and its shorted out the trip in the control unit. you will need to remove the air bag, ( battery off car wait 20min ) remove the air bag. and have it tested. there have been a lot of copy air bags been reported and they are more dangerous than they should be cause electrical fires or in an accident they explode in your face. and when explode they do do some damage to your face..... would have this check.
Mar 22, 2014 | Dodge Intrepid Cars & Trucks
Circuit unit behind the ac controls
sounds like your blower motor has stopped working check for power going to the blower system if you have power the blower is probably bad the concern is the lack of a fuse blowing or a breaker not cycling you may have a harness problem sometimes a low grade short will heat up wires then melt them together causing a multisystem failure even though a fuse or breaker didn't blow check you harness
Aug 09, 2012 | Dodge Avenger Cars & Trucks
Turned on the air conditioner, it ran for 5 seconds, then switched off. I now have no power lights or anything on the control panel (a MICOM MKK Control). Have tried turning the power off at the switch...
As you don't mention error code, out of two reasons, you check one by one.
1. First check manually rotate the blower wheel. If it hard to rotate, blower motor mechanism blocked.Replace bearings or motor.
2.Your indoor coil and room sensor defective. Replace it. Is it helpful.
Dec 30, 2010 | Heating & Cooling
I've had to replace the blower motor on an old GE electric furnace three times in the past year. The first time the motor just stopped working. So I replaced it with an A.O. Smith motor for the summer. It...
This is definately not a good thing. This unit is a safety hazard to say the least. Check for recalls by reporting it to the consumer product safety.
Jun 12, 2009 | Heating & Cooling
After turning the unit on, it clicks to start, but then clicks right back off...
once you switch the unit off mid cycle, it needs time to equalise before it will switch on again.  otherwise check the start the compressor.
Sep 13, 2007 | Whirlpool ACQ122XK Air Conditioner
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
