My unit stop working I turn power off and on the unit ran for obout 5 second blower didnt turn on The air only option works on thermastate and blower airI check unit outside and was real hot .
  • Heating & Co... Master
  • 1,781 Answers
I don't understand. It sounds as if your outdoor fan is not running and is shutting down on thermal overload. Check capacitor in outdoor unit. Good Luck.
Posted on Apr 29, 2017
Why does air conditioning unit stop after the second setting
Setting ? As in the speed of the blower ? If the speed of the blower is the problem check the resistor unit in the blower box unit probably under the hood. What year and engine size ?
Jul 29, 2014 | Dodge Dakota Cars & Trucks
Turnsignal switch, brake switch,windows, and heater blower stoped workingdodge electrical problems
air bag power runs off the same power line you may have a faulty air bag been fitted.it may have burn't out the voltage control unit for the ignition. or the air bag has not been wire'd in properly and its shorted out the trip in the control unit. you will need to remove the air bag, ( battery off car wait 20min ) remove the air bag. and have it tested. there have been a lot of copy air bags been reported and they are more dangerous than they should be cause electrical fires or in an accident they explode in your face. and when explode they do do some damage to your face..... would have this check.
Mar 22, 2014 | Dodge Intrepid Cars & Trucks
Setting timer on window unit to turn on and off
Hi Jessica Yacopino - Generally speaking, Frigidaire air conditioners timer option typically have the same procedure. The unit must be in the ON position for the timer delay stop option. For delay start, the unit must be in the OFF position. First, press time button. Then to adjust timer setting, tap or hold the UP arrow or the DOWN arrow to change delay timer at .5 hour increments, up to 10 hours, then by 1 hour increments up to 24 hours. The control will count down the time remaining until start (8, 7.5, 7, etc.). The Delay Start mode automatically selects cooling with maximum Fan Speed. The temperature maintained will be the same as previously set. To change the set temperature, press "COOL" then Up or Down arrows until the desired temperature is indicated on the display. After 5 seconds, the control will automatically change the display back to the hours remaining until the unit will start/stop. PRESSING the unit On/Off button at any time will cancel the Delay Start/Stop function. The Delay Start/Stop Feature will work until the unit either starts or stops. Once that happens the above steps have to be repeated again.
Oct 03, 2012 | Frigidaire FAS257S2A WallWindow Air...
My A/C and hear is not working, check all the fuses and still nothing. what else could be the problem
i guessing your talking about the blower motor not working.if the fuses are good then you will have to check for power at the blower motor itself and ground.if you don`t have power to the motor it could be the blower motor resisitor under the hood located on the air duct with about 5-6 wires on it.check for power to this and power out on one of the wires with the switch turned on.if you have no power out then you will have to replace the resistor block.
Dec 07, 2011 | 1997 Buick LeSabre
My trane xe 1000 central air conditioning unit turns on and the fan os working, but no air is coming into tue house. The lines get ice on them outside. I left it off all night with no change in status
If you left it off all night and no air is coming out of supply registers then the blower motor is not running. If the system is getting frost on the suction line(the big copper line coming out of the outside condensing unit with rubber insulation on it) within minutes of turning the system on then that will confirm that the blower motor is not running properly.
Unless you are very experienced in working on air conditioning, i would call a professional to do the repair.
If the motor has to be replaced its takes an experienced technician to do it correctly.
It could simply be the run capacitor on the blower motor.
This is probably going to be a 5 mfd capacitor.
Turn off all power to air handler, remove service panel, set your multi-meter to mfd (microfarads),
place the leads on the connections on top of the capacitors securely for 5 seconds. You should read about 4.8 to 5, if not the capacitor is bad.
There are other possible problems that could cause your symptoms, but ultimately your blower fan is not blowing air.
Sep 01, 2011 | Heating & Cooling
Hi my polo heater has stop working . i have change the stat ,still not working
hi are you getting just cold air blowing when you turn it on or are you getting nothing at all if you have changed the thermostat then the chances are the whole control unit needs replacing these do fail from time to time if your getting the blower working but only getting cold air then you need to change the control unit.
your cheapest option would be to buy second hand they can be hard to fit so be warned.
let me know how you get on or if you need further assistance ok
Nov 10, 2009 | Televison & Video
Stihl bg 55 blower runs good for 5 min. then loses power
1) carburetor gaskets/diaphragms may need to be replaced
2) ignition coil may be breaking down when hot
3) check compression when cold, then after it stops, when hot
4) could have a vacuum/pressure leak
*I would investigate carb first
Nov 08, 2009 | Garden
After turning the unit on, it clicks to start, but then clicks right back off...
once you switch the unit off mid cycle, it needs time to equalise before it will switch on again.  otherwise check the cap.to start the compressor.
Sep 13, 2007 | Whirlpool ACQ122XK Air Conditioner
Runs doesn't cool
where is the air filter for the ruud ( #uak037jaz) air conditioner
Sep 05, 2007 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
