SOURCE: The duet washing machine fills up with water in between loads. What is Causing This?
Dont want to endorse a commercial site, but you can by a generic part for a bit over $10 for this problem, so do some seraching for a reasonable site (other sites are charging 40-50 dollars for a fill valve.
SOURCE: washing machine wont empty
hi there this is a common fault empty the water into a bucket and remove the water pump to check for blockages, the pump is located at the rerar lefthand side of the w/m.
also check your drain hose where it connects under your sink.
hope this helps
SOURCE: Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
SOURCE: Filling With Water
This is probably a control board failure, which should be replaced by someone familiar with them.
If you are handy, you can do it yourself.
If you need assistance, let me know.
SOURCE: Washer will not fill all the way.
you may have to adjust/replace the water level switch. it is located behind the control panel. the water level knob is attached to it. it does have a screw adjustment.
