What is the toe panel on a washing machine - Washing Machines
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
A toe panel is also called a kick panel or kick strip or base plate. It's the lower piece on older model washers and dryers, although you don't see it much on newer units because the entire front is one piece and has to be removed as an entire unit.
Posted on Apr 29, 2017
I am getting a musty smell from the washer and from the clothes that come out of the washer. I have heard that there is a filter inside the toe kick panel that can be cleaned out. Is this true? What else...
true remove toe panel and wash murk out of plastic filter,,replace tightly or it will leak...also wash unit out with 12 to 16 ounces of bleach as needed...always unplug first
Aug 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water wont go into the machine but yet all the lights are on
It sounds like you have a hose leaking.You can check the hose leaking by opening the washer door & inspecting the rubber boot that goes around the perimeter of the tubs. It is secured in place by two clamps.In order to check if the leak is underneath the washer tub you will first need to disconnect electrical power to the washer.Remove the three screws securing the toe panel to the front of the washer and remove the toe panel by lifting slightly and pulling forward.
Hope this helps.
Shane
Apr 22, 2011 | Indesit W 123 Front Load Washer
The washing machine flashes F 20
"F20" is a "No Water Detect" error code. This usually means you have very little water entering the machine, or no water at all. The following link explains the error code in more detail and steps necessary to troubleshoot:
http://www.fixya.com/support/r3608632-f20_error_code
If you have any questions, please post back and let me know. I hope this information is helpful to you.
NOTE: Each one of thes washers comes with a technical data sheet inside. The tech sheet lists all error codes, troubleshooting information, wiring diagrams, diagnostics procedures and illustrations. To access, you need to remove the lower toe panel directly below the door. The screws are located under the bottom front edge. With the screws removed, the panel will drop down and can be removed. If the tech sheet is not located dorectly behind the toe panel, it will be affixed to one of the interior cabinet walls.
Mar 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When fill the water it goes to out hole if machine not switched on
Hope this helps.
Shane
Feb 12, 2011 | Whirlpool WTW5500X Washer
Can I take off the front panel of a Kenmore/Whirlpool washer to change the bellow?
Removing the boot will require that the front panel, door switch and console be removed.
To remove the front panel first remove the three screws securing the toe panel to the front of the washer and lift the toe panel up slightly pulling it forward.
Next remove the two screws securing the top front panel to the washer. The front panel can now be removed.
Jan 27, 2011 | Kenmore 44102 Front Load Washer
Control locked how to unlock
Sometimes fiddling with the machine controls you can get it to release. By fiddling I'm talking about selecting a cycle and then trying to cancel by hitting the cancel/stop/pause button. If this does not work and unplugging the machine does not work, you are going to have to manually do this.
First, unplug the machine. Next, at the bottom of the machine is a toe panel. Under the panel are typically 2-4 screws. Remove these screws (either 1/4 or 9/32 nut driver) and place the toe panel aside. Now, you can reach up underneath the door lock assembly which should be on the right side of the washer door (opposite side of the door hinges). You will have to feel around, but u can pull down on a plastic "catch" or lever. This will unlock the door!
May 28, 2010 | Whirlpool GHW9400 Front Load Washer
How do I clean my whirlpool washing machine pump? The red light of my washing machine is on and it is saying clean washing machine pump and my washing machine door won't open.
rmove the 3 screws ot the bottom of toe panel . pull down and out to remove . pump is just right of center . about a 3 in lid rigt in front turn t open and clean out tray . mm.
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I got a asko front loader 50005 washing machine and loss power to it. I need to git my clothes out of the washer. How can I do this?
you can remove the toe panel ... remove the screw and pull the red release string... this will get your clothes out..
Jun 03, 2009 | Asko W6461 Front Load Washer
I need help please
if u take the bottom toe panel off there should be a tech sheet either on the toe panel or on the inside wall should have the diagram in it hope that helps
Mar 10, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore He4t frontloading machine flashing F 02
U have something stuck in your water pump u need a torx 20 and some hose clamps unplug the machine take the three torx screws off the toe panel put the hose clamps on the white plastic waterpumps hose that goes from the back of the pump to the bottom of the drum unscrew the pump to the left and pull out you can also use the toe panel to catch some of the water pull anthing out of it that u can and replace everything back try taht first
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
