My washing machine door has dropped and will not open is they anything I can do myself to unlock it?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
Much of the answer to this depends on the model of your machine, but I'll take a shot at it this way.
Firstly, I'm assuming this is a top-loading machine with a hinged door. If so, you'll see the entire top is separate from the base (a small seam goes clear around your washer) which can be raised.
(see photo)
You might need to pull the machine away from the wall slightly to get clearance and you will probably also require use of something to use as a pry bar, like a big screwdriver.
Place your screwdriver tip in that seam and twist slightly, so as to not damage your finish. It might require a few tries, but the top will pop away from the bottom.
Once you raise the top section (that includes the lid and the big opening your put your clothes in) you'll see the drum and the stop mechanism just underneath the lid.
There will be some sort of latch there, and it'll be lodged through a loop that prevents you from raising the lid. Manually push that catch away and raise your lid, then once it's secured, lower the entire top back and snap it back into place.
My washing machine door has dropped and will not o - dsc00587-0surpdtci0xip2xld3tgvz2h-2-0.jpg
Posted on Apr 29, 2017
How can I unlock the door to my Whirlpool Duet washing machine?
try this link..Pull down on the bottom panel and pull it away from the washer. Reach through the open panel and up to the door lock. Find the release ring below the locking mechanism. Pull down on the ring to unlock the door.
How to Unlock a Whirlpool Duet Washing Machine ' Home Guides ' SF ...
homeguides.sfgate.com/unlock-whirlpool-duet-washing-machine-68645.html How can unlock the door to my Whirlpool Duet washing machine Google Search
Dec 12, 2016 | Whirlpool Washing Machines
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Whirlpool duet washer door will not unlock or complete the cycle
  • Oct 13, 2011 | Whirlpool Washing Machines
    We have a whirlpool duet front load washing machine door is stuck closed. i have unplugged machine still wont open?? any solutions i can try myself before i call a repair person??
    You can manually unlock it. Unplug washer. On the lower panel there are 3 screws, either 1/4 inch or they are the hex bit. Remove these screws and the panel will come off. Reach up on the inside on the right side. You will be able to feel the door lock mechanism, near the bottom of the mechanism is a pull release lever, pull down on it and the door will unlock. The door lock may need to be replaced. I hope this helps
    Feb 28, 2011 | Washing Machines
    Door not unlocking, washer still full of water
    Door will not open due o water in the machine .drain it Manully drop down hose to floor level with a bucket it should drain due to Gravity,this will now allow door to open next remove check/clean filter pump....
    Jan 09, 2011 | Washing Machines
    Cnt get door unlocked on washer
    If water is in machine drop drain hose to floor level to drain off door should now open..good luck
    Sep 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool duet front load washer, DFL code
    Here are the steps to unlocking the door manually
    1.Unplug machine
    2.remove bottom panel
    3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
    4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
    5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
    6. You may now open the door.
    This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
    Nov 21, 2008 | Washing Machines
    Whirlpool Duett Front load washer, DFL code door won't unlock?
    1.Unplug machine
    Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Theres a load stuck in my washing machine. the washer will not start. it keeps saying "dL" and "f". the owners manual does not say anything about "dL" what do i do?
    Hi xstar57x
    This suggest problems with the door lock/unlock mechanism
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
    • Check Door Lock/Switch Assembly
    • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
    Replace failed component
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Note: The door lock/switch assembly can be manually unlocked.
    To Manually unlock the door lock system:
    1. Unplug the power cord from the outlet.
    2. Remove the lower toe panel.
    3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
    4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
    5. Gently pull the tab down about 1/4 inch or until a click is heard.
    6. The door may now be opened.
    Regards
    Nov 16, 2008 | Whirlpool Washing Machines
    Hoover Washing M/C Door Jammed
    we had the same problem on ours, a techy came out to it and hit the washer above and the the right of the door handle, and hey presto the door opened, have done this myself since, works everytime
    Nov 03, 2008 | Hoover AAA160 Front Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
