Question about Aqua Pool & Spa
My Aqua Logic read out says 32v 00a.Also shows 0000ppm. I just cleaned the cell and I know there is salt in the water. Our pool is about 15,000 gal. The cell is about 3 yrs old.
    Top Expert:
  • Aqua Master
  • 7,919 Answers
Bad sensor
Posted on Nov 12, 2017
  • 10 Answers
SOURCE: Too much salt in pool (4,100)
the leslies employe is right the only way to get rid of the high salt level is to drain the water i would say drain a 3rd and fill pool and check salt level some salt genarators can not make chlorine at high salt levels or when the water is cold
Posted on May 19, 2009
Coastsider
  • 331 Answers
SOURCE: My Zodiac LM3 chlorine generator shows on my
You are supposed to be maintaining between 4000-7000 ppm according to the manual you can read here...
http://www.zodiac.com.au/media/25135/zodiac%20lm3%20owners%20manual.pdf
Posted on Apr 14, 2010
  • 8404 Answers
SOURCE: 12500 gal pool began by adding 8 \ 40# bags of
You have too much salt in the pool ...dump some water.
You have too much CL in the pool ... turn off your cell ... add some chlorine killer if necessary. The sun will eat new CL pretty fast.
You have metal in the water ... the CL aggrivates the metal, turns the water green ... If your pool were plaster, you would be in danger of serious staining.
You may have some alg. but I doubt it with all the stuff you have inthe pool
Check the source of your information.
Here is what you should consider ...
Fill the pool ... get rid of the metal ... 3 oz per 1000 gallons is the recommended dose ... NO CL for two days. Metal out works best when there is no CL in the water.
Get the TA under control and the pH. With the TA at 100 and pH at 7.4, bring the CL up to 2 or 3 ppm. You don't need CA ... but you might want to add some for comfort purposes. You might want to add cynauric acid to about 35 ppm to protect the CL. CA and cynauric acid are not consumable ... if you have a lot and want to get rid of it ... the only way is to add fresh water.
If you have more questions ... please post to this question.
Thanks for your interest in FixYa.com
Posted on Jun 01, 2010
  • 3 Answers
SOURCE: My Aqua logic chlorine generator reads
See on www.manulabo.com/hayward to have your free solution
Posted on Jul 06, 2010
  • 368 Answers
SOURCE: We have a 18x48 ultra
I can't explain all of this but to get the rid of the green and reduce the salt level you need to drain half the water and refill. At this you need to shock it so the chlorine is up to about 10 ppm. You need some way of testing to tell this. If your chlorinator is ok then when you start the pump and chlorinator it should continue cleaning it out. The dead algae will be filtered out with the filter. If the flow slows down you will need to clean the filter with a water sprayer on a hose. I hope this helps.
Posted on Aug 09, 2011
Installed new t-cell and it still says salt level is zero, but the t-cell trips out on high salts,amps. What is the problem?
Depending on the water temperature the actual salt level reading can be inaccurate.
If the water temp is below 65 the reading will sometimes show a lower salt level than the actual level.
Did you recalibrate the power center?
Have you tested the salt level independently?
I would first test the water or have it tested, many pool stores offer this service for free.
It helps to have an accurate reading and not rely on salt test strips.
Once you know the actual salt level you can attemptrecalibrate the system and see what reading you get.
For an aqua rite system you flip the toggle to super chlor, to off and back to auto , wait 5-10 seconds you will hear a click then press the button next to the display , tI'll you see the salt level calibrating.
Oct 25, 2016 | Pool & Spa
Goldline controls troubleshooting
hold control down it will change to standard or go into set up
Aug 02, 2014 | Hayward Pool Products Hayward Aqua Rite...
Haywardnet com
bad sensor and clean cell if ok replace both
Jun 01, 2013 | Goldline Salt System Transformer -...
Hayward Aqua Rite Not showing salt and temp readings
see if voltage from transformer if ok bad control board or sensor
Jul 09, 2012 | Hayward Pool Products Hayward Aqua Rite...
Drain this pool, give it a good cleaning and start over. Clean the electrolytic cell. Your 24" x 52" size pool holds 12,481 gallons of water and requires 310 pounds of salt at initial startup. You should set the timer to run 11 hours per day. If the low salt light comes on add 85 pounds. You need an owner's manual. You can download one here. http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Jun 01, 2010 | Intex Automatic Salt Water System for ...
Clorinator off no cell power.
"no power to cell" on my salt water chlorinator.
Mar 28, 2010 | Aqua Hayward Logic PS-16 Pool & Spa...
Pool & Spa Logo
Top Aqua Pool & Spa Experts
Larry Maranto
Ben Clacy
Ben Clacy
Level 1 Expert
Are you an Aqua Pool and Spa Expert? Answer questions, earn points and help others
