Question about Elna Sewing Machines
How do you adjust the tension control on an Elna lotus SP
  • cswilki Apr 29, 2017
    I took off the tension knob. How do reinstall and set tension for universal? Then put the knob back on? Is it a certain thread at x # of inch pounds?
  • Elna Master
  • 11,177 Answers
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna Lotus Instruction Booklet
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
Posted on Apr 29, 2017
I have an old elna lotus sp sewing machine and need to reduce the speed on the foot control is this possible
The Lotus should have the integrated foot controller and power cord in one. Some of these had a switch on the foot controller which reduced the power to half speed. That's the only way to adjust the speed other than the foot on the pedal. The later models Air Electronic have a slide speed control on the front face of the machine which made life easier.
May 06, 2017 | Elna Sewing Machines
Winding bobbin on old elna lotus
I can help you with this, the Elna Lotus has a pretty simple bobbin winding system, the bobbin winder is top right of the machine, drop bobbin with holes to the top onto the spindle. Now Lotus have a dial on the right side which switches between bobbin winding, stitching and locked for transport, turn it to Bobbin symbol. Take the thread from the spool pin at the back across to the metal eyelet at top front (it sits inside the accessory tray when transporting so you may need to pop open the tray lid and flip this eyelet out)
24421001-h4211ohbpts0t3j0sbmab0vm-2-0.jpg Now take thread across and through a hole on top of the bobbin and holding the tail, put your foot onto the foot control to get a couple of winds onto the bobbin to hold the thread. Now place your finger or the handle of a pair of scissors onto the top of the thread spool to apply tension so that the thread winds evenly and slowly wind the bobbin until about 3/4 full, making sure it winds evenly. Tension onto the spool is the key here, Lotus doesn't have a tension device to control the thread tension as it winds so you need to do this, critical to getting a good stitch out of these lovely machines.
Hope this helps you out.
May 14, 2014 | Elna Sewing Machines
Manual for elna lotus sp
follow this link for free download
http://www.scribd.com/doc/25386753/Elna-Lotus-Sewing-Instruction-Manual Elna Lotus Sewing Instruction Manual
May 06, 2014 | Elna 2007 Mechanical Sewing Machine
Thread from the bobbin is not getting looped
If the bobbin case rotates freely it is probable that the pinion gear is broken. Replace the gear, retime machine and voila it works again. Trouble is tough to find the gear anymore good luck it is a good machine and worth the effort
Jan 09, 2014 | Elna Sewing Machines
I inherited my mother's Elna Lotus SP sewing machine. She had the sewing guide inside the machine, but not the instruction manual. I need to know how about the bobbin and how to thread?
Hi Jeanne, you might want to check out my tip on early Swiss Elnas,
http://www.fixya.com/support/r10602655-acquired_early_swiss_elna_sewing
it should help you get the Lotus going. Lovely machine. If you are in the USA you may also want to contact White Sewing Center as he may have this manual available for sale or a copy of it. www.whitesewingcenter.com.
Remember to use the Elna 7 hole dished metal bobbins, there are 7 holes on the top, and looks like this11_7_2011_6_23_57_am.jpg
Always wind it and insert it into the machine this way. Don't use any other bobbin. Standard needles 130/705H, flat shank to the back.
Check out my other tip on bobbin winding too, it is important to keep tension onto the thread spool that you are winding thread off as the machine doesn't tension the thread for you. So you need to apply pressure to the top of the thread spool as you wind off, use the curved handle of your scissors on the top of the spool.
Feel free to connect to me and ask if you have any other questions, I have a Lotus TSP at home and its almost identical to the SP. Happy stitching.
Oct 30, 2011 | Elna 2007 Mechanical Sewing Machine
How do you time an elna lotus sp
Maurice, I've found this image from the Supermatic service manual for timing adjustments, sorry, I don't know if the lotus is the same but it might give you some clues as to where the hook and needle need to be.
Oct 20, 2011 | Sewing Machines
Manual for Elna lotus sp model 35 m703163
Nov 06, 2009 | Elna Sewing Machines
What bobbins will work with a vintage Elna Lotus SP sewing machine?
I did a search and found this post for you. I hope it will help.
The best-known Elna guru is Ray White, aka "Elnaman". He teaches classes on sewing machine repair but his speciality is Elnas. You can order parts or contact him at his website:
http://www.whitesewingcenter.com/index.p…
or you can contact him directly at:
Ray White
White Sewing Machine Center
PO Box 73
Bellview, MO 63623
Phone: 573-697-5841
elnaman@whitesewingcenter.com
You can also join the yahoo group "elnaheirloomsewingmachines" where very knowledgeable Elna owners/collectors share information and answer questions. Enjoy your Lotus!
Sep 02, 2009 | Elna Sewing Machines
Sewing Machines Logo
78 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
