Question about Canon PIXMA MP460 All-In-One InkJet Printer
Will not print - keeps reporting imaginary paper jam. I bought this at Staples in Ontario, Canada 1-1/2 years ago, where do I take it for service?
    Sergeant:
    Novelist:
  • 192 Answers
Go to Canon.ca. They should have a list of repair centers closest to you.
However, you should note. It is actually cheaper nowadays to get a new printer if your printer is not under warranty. At around 40 dollars an hours minimum, it is cheaper to buy a new one. Go with a color laser printer. It will save you about 500 dollars in ink over the life of a printer. Check it out.
Posted on Jul 25, 2009
Just recently my Epson RX630 will not print when copying. Keeps coming up paper jammed. But it's not jammed. Prints OK via PC documents. Is there remedy? Tom.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQ&oid=44341&prodoid=54782584&foid=238721
Contact Support
United States Phone Number:
(562)276-4382
Hours: Mon.- Fri. spacer.gif 6AM-8PM (PT) Sat. spacer.gif 7AM-4PM (PT)
Canada Phone Number:
(905)709-3839
Mail line_dkblue.gif spacer.gif United States
Epson America, Inc.
3840 Kilroy Airport Way
Long Beach, CA 90806-2469
USA Canada
Epson Canada, Limited
185 Renfrew Drive,
Markham, Ontario L3R 6G3
Canada
Miscellaneous line_dkblue.gif spacer.gif Third Party Contacts Non-Epson resources Epson Developer Program Programming and Linux information Impact Printers Developer Program (EpsonExpert) Programming Info
Replacement Parts for Epson Products (US Only) Compass Micro, Inc. (800)388-8595 Encompass Parts Distribution (formerly Vance Baldwin) (800)432-8542 Micrologic Systems, Inc. (903)561-0007 National Parts Depot (800)524-8338 TSAworld, Inc. (800)633-6626
Nov 16, 2014 | Epson RX630 All-In-One InkJet Printer
Tip
Lexmark laser paper jams and wrong size paper reporting
the quickest way to find out if your paper jams are due to wrong size paper reporting is to print the network status page.
This page is outline with a line that runs 1/2inch from the edge all the way around the outer edge.
if the box of this page prints smaller than the letter size paper the paper reporting is smaller than 8 1/2 x 11 and if the line at the bottom of the page is missing its reporting a size larger than 8 1/2 x 11 either of these occurances willl be the cause of your paper jams
on Jun 07, 2010 | Office Equipment & Supplies
I have a 18 mo old 8500 OJPro wireless that won't advance the paper, makes a clicking sound and gives a false paper jam error. I have seen a split white gear within a black clutch assembly on the left end...
Follow these steps in the order presented to resolve the paper jam. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c02073375.gif c01994705.gif Step two: Clear the jam from the rear of the product CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Turn the product around so that you can access the rear side. Figure 1: The rear side of the productc01617574.gif
  5. Push in the button on either side of the two-sided printing accessory (duplexer), and then remove the duplexer. Figure 2: Remove the duplexerc02051407.gif 1 - Press the buttons on the sides of the duplexer 2 - Pull the duplexer out of product
  6. Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull any whole sheets of paper to avoid tearing them. Figure 3: Gently remove the jammed paperc02073376.gif CAUTION: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 4: Remove scraps of paperc02073377.gif
  7. If you do not see jammed paper in the rear access area, push the buttons on the latch on the rear of the duplexer, and then lower the cover. Figure 5: Open the duplexerc01617577.gif 1 - Latch on rear of the duplexer 2 - Duplexer cover
  8. Remove any jammed paper from inside the duplexer.
  9. Close the duplexer cover.
  10. Gently push the duplexer into the product until it snaps firmly into place. Do not press the buttons on the end of the accessory while you reattach it. Figure 6: Reattach the duplexerc01617578.gif
  11. Reconnect the power cord to the rear of the product.
  12. Plug the power cord back into the wall outlet.
  13. Press the Power button (c01602202.gif ) to turn on the product.
Step three: Print a self-test report Follow these steps to print a self-test report. Printing a self-test report verifies if the hardware functions correctly.
  1. Load unused, plain white paper in the input tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press the Setup button (c01726396.gif ).
  4. Press the Right Arrow (c01185072.jpg ) to select Print Report , and then press OK .
  5. Press the Right Arrow (c01185072.jpg ) to select Self-Test Report , and then press OK . The self-test report prints.
Oct 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
Constant paper jam
How do you put the paper in?It must either be the paper or the paper feed system.
Apr 27, 2008 | Samsung ML-2510 Laser Printer
Continually getting paper jams. Not picking up the paper. probably needs cleaning and maintenace. Bought at staples a couple of years ago. Where can I get service. Model is Intellifax 4750
Have you tried to clean the feed rollers yourself?
I would try cleaning the feed rollers before bringing it in for service.
You can slide the paper drawer completely out, and then look under the machine to find the feed rollers.
Usually they are Gray.
There is a chemical that you can buy at your local hardware store called "Goo Gone". This is a cleaning chemical that will clean the rollers and not dry out the rollers like alcohol would.
I hope this helps.
Good luck.
Mac =)
Feel free to ask more questions if you have any.
Mar 21, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Pohot paper jamming in Brother DCP-115C printer
This is a common error of this printertype. Please use only paper of max. 220g. There is no problem reported with that.
Jan 14, 2007 | Brother DCP-110C All-In-One InkJet Printer
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
102 people viewed this question
old marine
old marine
