Question about Diamond Computers & Internet
Where to find Diamond Technology Audio speakers usb 2.0 drivers
I need a manual for Diamond Audio's D971 component speakers, I need the thiele small parameters of these speakers
General •Speaker type car speaker Manufacturer Diamond Audio Technology Inc. Features •Amplification type passive •Driver configuration 2-way •Woofer size (inches) 7" m, 30mm m •Nominal (RMS) output power 200 Watt •Max (RMS) output power 400 Watt •Response bandwidth 35 - 30000 Hz •Input impedance 4 Ohm •Sensitivity 92 dB •Connectivity wired Compatibility ' Accessories •Included accessories mounting hardware Cutout & Mounting Dimensions •Diameter 6.3 in •Depth 2.7 in General •Manufacturer Diamond Audio Technology Inc. Thiss should help you out.
Jan 05, 2015 | Diamond Audio Car Audio & Video
Diamond 8.4 serie are there 2 way or 3 way
These speakers are 3-way there are 2 woofers and 1 tweeter per speaker. Here are the technical specifications of each speaker:
Two 6.5-inch Kevlar woofers and 1-inch silk-dome tweeter per speaker
86 dB sensitivity
20 to 150 watts recommended power (per channel)
6 ohms impedance
30 to 20,000 Hz frequency response
Please rate my answer if this helps.
Many thanks,
Mar 02, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
My diamond storm speakers wont work
if they are on a computer and are not working you can try
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 06, 2010 | Packard Bell Speaker Computer Speakers
Recently re-installed windows xp on my e-machines T2542 and now my speakers (Diamond Audio Techonology Model EMC2.0-USB) do not work. I downloaded RealTek AC '97 Audio, but it does not show up in my Device...
Good day sir, hi, the realtek you downloaded maybe is not the correct driver, the driver is the ALC202 from this website:
You can visit this site for the driver:
Run the driver once again, when windows detect the device, dont reply, just let the driver finish the installation. then restart the pc. thats it. thanks
Nov 04, 2009 | E-Machines T2542 PC Desktop
My computer does not regonize any audio devices
From a distance, it sounds like you do not have the sound card drivers installed. Since it is a SoundBlaster card, go to and download a utility that finds, indentifies, and then installs the drivers for your sound card. That should fix the problem. If not, then you have other issues going on with motherboard drivers not being installed installed.
Jun 06, 2009 | Audio Players & Recorders
My desktop speakers don't work.
What do you mean, "cleaned out my computer"? If you mean removing software then you've probably removed drivers for the audio hardware in your computer. If you got a "driver" disk with your computer, re-install the sound drivers and you'll be up n running in no time !!!
Apr 14, 2009 | Logitech Spin 75 Computer Speakers
Looking to see if there are rca hook ups on subwoofer
There are not RCA Hookups on any Raw Subwoofer. An amplifier takes an RCA input signal (DC) and turns it into AC to the speaker.
This is a raw driver. It has wire push terminals just like any other driver (speaker).
See here....
Thanks for using FixYa - A FixYa Rating is appreciated!!
Jan 22, 2009 | Diamond Audio TDX-10D4 Car Subwoofer
USB Audio Device Drive Load Failure
Driver probably needs update. I had this problem using my usb speakers until updating driver to newest version.
Dec 21, 2008 | Logitech V20 Computer Speakers
Computers & Internet Logo
26 people viewed this question
Top Diamond Computers & Internet Experts
Tom Chichester
Jean DeLauche
Jean DeLauche
Are you a Diamond Computer and Internet Expert? Answer questions, earn points and help others
