Diamond Technology usb speakers driver - Audio Players & Recorders
I need a manual for Diamond Audio's D971 component speakers, I need the thiele small parameters of these speakers
General •Speaker type car speaker Manufacturer Diamond Audio Technology Inc. Features •Amplification type passive •Driver configuration 2-way •Woofer size (inches) 7" m, 30mm m •Nominal (RMS) output power 200 Watt •Max (RMS) output power 400 Watt •Response bandwidth 35 - 30000 Hz •Input impedance 4 Ohm •Sensitivity 92 dB •Connectivity wired Compatibility ' Accessories •Included accessories mounting hardware Cutout & Mounting Dimensions •Diameter 6.3 in •Depth 2.7 in General •Manufacturer Diamond Audio Technology Inc. Thiss should help you out.
Jan 05, 2015 | Diamond Audio Car Audio & Video
Diamond vc500 "usb device not recognized" i have a
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Oct 21, 2011 | Diamond Multimedia ( VC500) Video Capture
Diamond 8.4 serie are there 2 way or 3 way
These speakers are 3-way there are 2 woofers and 1 tweeter per speaker. Here are the technical specifications of each speaker:
Two 6.5-inch Kevlar woofers and 1-inch silk-dome tweeter per speaker
86 dB sensitivity
20 to 150 watts recommended power (per channel)
6 ohms impedance
30 to 20,000 Hz frequency response
Please rate my answer if this helps.
Many thanks,
Mar 02, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
Can't get the back off of my Wharfedale Diamond's. Model 7.1
Sometimes the back does not come off, but the speaker comes out from the front...
Mar 22, 2010 | Wharfedale Diamond 8.3 Main / Stereo...
My computer does not regonize any audio devices
From a distance, it sounds like you do not have the sound card drivers installed. Since it is a SoundBlaster card, go to and download a utility that finds, indentifies, and then installs the drivers for your sound card. That should fix the problem. If not, then you have other issues going on with motherboard drivers not being installed installed.
Jun 06, 2009 | Audio Players & Recorders
Drivers swap
With some speaker cabinets, the manufacturer will put some form of adhesive to seal the speaker to the cabinet so there's no space between them. I've often found that all it takes is to use a thin bladed flat screwdriver and insert it gently between the speaker frame and the cabinet to break the seal and free the speaker. You may need to tap the screwdriver in a bit, then twist it, but if you find you must use a lot of force, this may not be the solution for you. Please rate my answer, thanks.
Jun 02, 2009 | Wharfedale Diamond 8.4 Main / Stereo...
Driver for SupraMax 56k external usb for windows vista
this modem is not support the vista you have to go for the win xp or win 2000 i just give the link to download the driver for win xp or win 2000
May 10, 2009 | Computers & Internet
Looking to see if there are rca hook ups on subwoofer
There are not RCA Hookups on any Raw Subwoofer. An amplifier takes an RCA input signal (DC) and turns it into AC to the speaker.
This is a raw driver. It has wire push terminals just like any other driver (speaker).
See here....
Thanks for using FixYa - A FixYa Rating is appreciated!!
Jan 22, 2009 | Diamond Audio TDX-10D4 Car Subwoofer
26 people viewed this question
