Question about Coffee Makers & Espresso Machines
Nutrimill grinder gets very hot and isnt grinding as fast as it used to. what can I check
5 Suggested Answers
SOURCE: Hot steam dampens coffee grinds in grinder unit
These grinds are what is left after the grind process is finished. Everyones unit does this.
Posted on Mar 28, 2008
  • 515 Answers
SOURCE: Saeco coffee machine
I think your grinder engine has broken and have to be replaced.
Posted on Jul 18, 2008
SOURCE: Breville cafe roma
Obviously the problem is with your grind, not the Breville. SImply adjust your grind to finer.
Posted on Jan 07, 2009
SOURCE: Krups GVX2-12 Electric Burr - Thermal Fuse
Open the grinder by removing both knobs.
The front knob is held in place by friction. Use two flat head screwdrivers to pry it off.
The side knob is held in by tabs you have to push. Pry forward to expose the tab, and use another screwdriver to press the tab, and use the other screwdriver to press the tab on the other side.
Now look at the bottom of the grinder. There are four tabs on the outer shell, use screwdriver s to pry the tabs to separate the bottom of the grinder from the shell, and pull off the shell. Your fuse should be attached to the motor wiring coil.
Posted on Jun 27, 2009
Bunn g3 commercial grinder
Humm, G-3 grinders. Okay what common problems I've come across:
* Wrong setting for grind on label. Usually means worn out grinder burrs. But this does not happen often unless you are using it to grind commercial amounts of coffee? It's a retail level grinder meant to be user friendly and simple to use. Say grind a bag of beans once every 10 mins or so even with customers lined up to grind there own. Running a G-3 constantly is usually done by upcoming coffee vendors whom are using it for small flavored bean batches. But expect the burr plates to only last 3 to 6 months. We used to change it every month till the boss bought a bigger pro grinder. (whew!)
* Out of calibration (for grind) This usually happens as soon as it's installed. Either the grinder got banged (Dropped?) around or the lock nut was not tighten down. If caught quickly then it's a simple adjustment. Left unchecked will wear out the burrs or crack the plate.
* Trips out breaker. This is common at retail stores as it's located in a shelf rack that really does not have the required outlets. Many times there is a brewer(s) connected to the same line. It only trips out when one or both brewers are heating and the grinder is running a very fine grind.
* Trips out breaker when grinding espresso or very fine grinds. Worn burrs or slim chance the grinder was miss calibrated (but you would catch this when first installed)
* Shocks the customer. Dry climates or heavy air conditioning will build up static electricity at the chute. There usually a small chain attached to the chute to prevent this. Attach a SHORT metal chain or thin cable to the metal case of the grinder and add a metal clip to attach to the coffee bag. Many use a chain and clip just short enough to keep the bag positioned under the chute. Note many coffee bags come with bag clips. Just make sure the clip and chain can't get stuck in the grinder.
* Not working. This is usually the on/off switch as it gets beat up the most. There is sometimes a safety micro switch under the chute to sense if there is a bag there. I've found may have been defeated.
* No power, check cord, breaker (GFRI) outlet, Plug prongs if broken off or bent.
* power but no motor hum. Tripped thermal breaker (usually a red button on side or back. Some models may have it inside on the motor itself. Call for service to check.
* Turns on but loud hum (may be hot too). Burrs stuck. This could be from adjusting grinder while grinding beans and adjusting to a fine setting. Grinding finer slows down the beans feeding the burrs. Large settings flood the burrs with a lot of beans. Adjustments are usually done when the grinder hopper is completely empty. If loaded and turned down from coarse to fine grind the beans already in the burrs get crushed and stuck between the plates thus locking them in. It may be possible to clear the hopper and open up the grinder to its coarsest setting to jog out the crushed beans. Otherwise call for service to have the burrs cleared manually.
*Finally check with your vendor if your still having problems.
Aloha! ukeboy57
Mar 22, 2017 | Bunn Coffee Makers & Espresso Machines
How can we fix a nutri-mill wheat grinder?
can you see the grinding wheel /blades . if so try to rotate it /them slightly by hand
Dec 17, 2015 | Nutrimill Grain Mill Grinder
How do I dress a grinding wheel on a bench grinder with a viberating wheel.
First of all I must warn you of the dangers bench grinders can represent. Here in Britain no one connected with a business is allowed to carry out any maintenance on any none-portable grinding machine unless they have attended and passed a course on the subject and every employer must keep a register recording what maintenance has been carried out and by whom. Grinding machines have been responsible for many industrial "accidents".
Householders and private individuals are exempt from the Law but cannot afford to be less well informed even though the five and six inch bench grinders sold to the domestic user represent a somewhat reduced risk, great care and precautions are still required, not the least of which is the use of good eye protection even if the grinder is fitted with shields.
The first problem about dressing the grinding wheel of a grinder intended for the domestic market is the tool rests are usually too small and insubstantial for the vibrating star-wheel type wheel dressing tool to be used correctly.
A demonstration would be the best way to learn how to dress a grinding wheel and there are many available on Youtube and here is a link to a particularly good video.
Finally, it is best to be aware of one little thought about problem. There is an optimum speed range when a grinding wheel works efficiently and small domestic grinders barely turn fast enough for them to be properly efficient, probably because it is reckoned price and user safety takes priority over efficiency.
The speed that is of concern is the surface or peripheral speed of the grinding surface rather than the rpm of the spindle and should that speed fall too low the wheel will not be able to operate efficiently, will become dull more quickly with a greater tendency to clog and the wheel will become hot in use and hot grinding wheels soon become dangerous.
I hope you will be able to see that by reducing the diameter of a grinding wheel by dressing it also reduces the surface speed of the grinding surface even though the spindle speed remains the same. The relationship between surface speed and spindle speed is why small grinding points need to spin at 20,000 rpm and an eight foot wheel at just a few hundred rpm - in both cases the surface speed is similar.
A domestic grinder should not be used for heavy work but as the size of the wheel is reduced it should be used only for increasingly light work and if it is desired to carry out "normal" grinding operations it would be better to replace the wheel sooner rather than later.
Feb 19, 2015 | Craftsman Grinders
Mill won;t start
Thermister (over heat) is open or unsoldered. Other option, power wire inside has separated from switch.
Mar 05, 2014 | Nutrimill Grain Mill Grinder
Won't turn on
Possibly a piece of rock or other debris stuck in rotating portion....if it "hums" when powered on, you will need to invert it and shake it - or carefully tap it on a dishtowel to dislodge the stuck debris.
While using my dewalt 7amp small angle grinder (using it on and off about an hour grinding hard walnut wood) I heard a pop inside the unit so I turned it off, then a few seconds later turned it on again it...
burnt out the motor
the fix is a new unit
when grinding or sanding you use light pressure and let the disc do the work
change or unclog the pad or disc on a regular basis
for fast rip down use very course then finish with a fine pad
Jul 31, 2017 | Dewalt 65091601 Brush Set D28110 D28112...
I set the grind control know on the lowest number to try to get a fine grind, but I still get a coarse grind which does not give me a good expresso, and the water runs fast. What else can I do it is a...
More than likley you grinder has become seperated internally. You either need to disassemble the grinder completely, clean it and then try to reconnect the pieces or just replace the grinder. I have some. Just let me know, new or used reconditioned.
Jan 02, 2011 | Starbucks Saeco Italia Digital Barista...
Mar 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Breville cafe roma
Nov 14, 2007 | Breville ESP8XL Espresso Machine
Oct 05, 2007 | Saeco Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
26 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
