WD440P1400RPM. The Drying High Heat and On/Off button are flashing. I can't switch then off or cancel and cannot set any washing programmes.
fanny
  • 146 Answers
SOURCE: no heat on tumble dry programme. Display flashed F 13.
You need to replace the heating element for the dryer which is positioned on top of the outer drum. Remove the top cover of the machine and locate the heater.
Posted on Nov 01, 2007
SOURCE: WD440 drying high heat and 0n/off light flashing
The WD440 problem of flashing lights etc was solved by replacing the control unit, and this could only by done by a Hotpoint engineer who had a laptop, a satellite connection etc. etc... The unit cost was about £90, and by phone one was more or less forced to accept having to pay a £10 monthy.... !
Posted on Apr 28, 2008
Illeagle
  • 525 Answers
SOURCE: hotpoint ctd 40 is not
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
http://www.repairclinic.com/0088_8_1.asp
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 04, 2008
Benimur
  • 6966 Answers
SOURCE: F1 code on Fisher and Paykel dishdrawer
It would seem to be in an endless loop (firmware glitch). Initially, pls try:
  • unplug from the mains or switch off the breakers for a couple of minutes;
  • plug back in/switch on the breakers say after 20 minutes;
  • press POWER to turn drawer on;
  • Press and hold (at the same time) both the POWER and ECO buttons for a few seconds;
  • a five minute demonstration wash cycle will come on;
  • press POWER again to put unit on standby, all the LCD segments will start flashing (and light up);
  • press and hold START/PAUSE for a few seconds to hear confirmation beep/tune.
Alternately, should you have the two-drawer, open any drawer and look at the wash intensity/economy buttons. Now press them, one at a time, alternating between the two, at even timing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 15, 2008
  • 3 Answers
SOURCE: hotpoint aquarius
You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
Posted on Oct 23, 2008
I have an aeg washer dryer L87695NWD which is stuck on drying. When I turn the button to select a washing program the drying light stays on, and the washing light is still off.. what can I do?
From user manual:
10.4 At the end of the drying programme
1. The appliance stops automatically.
2. The acoustic signals operate (if they are active).
3. In the display (number "0") comes on.
4. The indicator of button Start/Pause goes off.
5. The last minutes of the drying cycle the appliance performs the
anticrease phase. The anti-crease symbol ietounus3lrwasi2ko2vq2k81km1my9gxk62inwk5r2qaaaabjru5erkjggga=flashes. The
door is still locked (the key ezfxrjud2vanwq0oeawt0sih4u7drnvleuvj3nru5hkbv+p2lq2ra1xbwbjeddwhka3byaaaaasuvork5cyiiasymbol is on).
6. Press button On/Off for some seconds to deactivate the
appliance. After some minutes from the end of the programme,
the energy saving function automatically deactivates the
appliance.
7. When the door locked light goes off you can open the door.
8. Remove the laundry from the appliance. Make sure that the drum
is empty.
9. Keep the door ajar, to prevent mildew and odours.
10. Close the water tap.
If this doesn't help than check:
- If the delay start is set, cancel the setting or wait for the end of
countdown.
- Deactivate the Child Lock function if it is on
If anything of this doesn't help then pay attention to all the symbols appears on the display and check what it means in the user manual.
Dado
Apr 01, 2017 | AEG Washing Machines
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
AEG OKO FAVORITE 4070 - AFter not using for a week dishwasher is flashing dry & end together, will not switch off unless turn it off at the power point, there is no water left in the machine.
If the END or DRYING indicator on the programme progress display is flashing, you can probably rectify the fault yourself.
After rectifying an END or DRYING fault, press the button for the wash programme that has been started.
The wash programme continues. If the fault is displayed again, than check water leakage in the battom of dishwasher.
Malfunction: END and DRYING on the programme progress display are flashing simultaneously.
Possible causes: The leak prevention system has been triggered.
Remedy: Try to find and repair water leakage otherwise close the tap and call customer service.
Dado
Mar 16, 2014 | AEG 24 in. Favorit 60870M Free-standing...
How to cancel drying?
Please press the reset switch which should be on the control panel or next to the loading door
Nov 14, 2009 | Indesit WA 115 Front Load Washer
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
I need an instruction manual for an Omega WD 1052 washer, please
I have searched everywhere as well, and no luck. I did find a bit of information on it which I have pasted below -- it might help a bit if you want to play around with it.
I would also suggest reading manuals from other wash/dryer machines to get an idea how they work--then maybe you can figure yours out by just pushing the different buttons and seeing what the display says. (At the end of this post, I have pasted a link to a different Omega washer/dryer -- perhaps you could skim it and see if it is at all similar to yours.)
Information About the Omega WD1052.2 washer dryer
THIRTEEN PROGRAMME:
The WD1052.2 is sequentially segmented into thirteen rotary positions for both easy and logical programme selection and for the quick identification of programme progression.
Choose from one of three wash sequences:
Programmes one through five are for the heavily soiled, more colour fast fabrics and daily wear.
Programmes six through to ten look after the slightly soiled, synthetics and for delicate items.
Woollens are exclusively washed on programmes eleven through to twelve.
CONDENSER DRYING:
The WD1052.2 can automatically dry a half a load of washing at the end of the wash programme provided the half load button is selected and a drying time is set on the centre control dial.
At any time the WD1052.2 can be regarded as an independent dryer, that is, a wash programme does not have to proceed into the drying stage. An example would be drying damp clothing or toweling from the bathroom. Simply choose a STOP position after either 5 or 10 on the programme dial. On the centre dial choose either full heat, the pink zone, or half heat, the green zone.
Another useful variation of the WD1052.2 is the ability to choose final spin only followed automatically by condenser drying. Having completed a hand wash, for instance, simply load the clothing and select final spin, 5 or 10 with the half load button selected and drying time set.
Whenever the WD1052.2 is in the drying mode the load can be easily accessed at any time via the porthole. The drying will automatically resume once the door is reshut.
Specifications:
Freestanding or Built-in
5kg (11lb) dry weight Capacity
2.5kg (5 1/2 lb ) dry weight condenser
13 Programmes
40 minute Fast Wash
Special universal 2B programme
Dedicated woollens cycle
Independent wash temperature control
1000 or 500 r.p.m spin speeds
Half load Economy selections
Drip dry no spin programming
Anti crease hold in final rinse Selection
Extra rinse option
Two drying heat settings
Stainless steel inner and outer wash drums
Two minute delay safety door release
Built-in heating element
Front mounted easy access lint/forgin matter
inspection
Automatic balancing of wash load
LINK TO A DIFFERENT MODEL:
http://www.omegaappliances.com.au/Documents/Document_205.pdf
Good Luck--I hope you get it working!
P.S. If you find this information useful, please remember to rate me! Thanks!
Mar 18, 2009 | Washing Machines
Hotpoint BWD129 1200 spin - unwanted drying cycles
This is more a workaround than a solution. When you choose the washing programme (say "D") and push the on/off button, two lights will flash, the "door locked" and the "drying" one. Now turn the "drying programme" button until the "drying" light stops flashing (in my case, this is true when I set the drying programme to 40°C). Then start the washing mashine.
Seems like the function of the drying programme button has shifted against the settings written on the button...don't ask me why! Of course, no guarantee but works for me. Please let me know if it does for you.
Oct 13, 2008 | QuietLine WD-9900 Front Load Washer /...
Hotpoint aquarius
Oct 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Just had the exact same problem and think I may have solved it. even turning power off didn't solve it. I think what happened was that the programme had been interupted while drying. I tried everything to get machine to work afterwards but only the following worked - while lights are flashing put back to the same time I had set to dry (60) in my case and turned the dial to M for dry high heat light goes off after a short while - leave for 5 mins then press off. machine will make a noise for a short while then stop.
If this happens then machine should be back to normal.
this is same for both posts I guess.
Feb 03, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
