My tv wont turn on just remains on standby tried with remote and manual buttons
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 20 Answers
Unplug it. Wait more than 10 seconds. Plug in and try again
Posted on Apr 29, 2017
My matsui tv 28WNO5(A) will not turn on from standby
Try pressing the small reset button on the back, it works, and you will not loose any stored information which caused the unit to go in the stand by mode.
Have you tried turning it off for an hour and then turning it back on. This happens to me quite often and leaving it off for a while ususally allows it to come back on. Also have you tried to press the TV/AV button on the remote as sometimes it switches to TV mode when its on standby and then standby won't work as its on TV mode and needs to go back on to AV mode. Basically just press the AV button on the digibox remote and then try standby.
if the batteries are removed and left for about 20 minutes before being replaced again, everything works as it should.
if any of the above suggestions does not work then you have to open the unit and on the main board of the tv there is a thin mini tube light like component called fuse you will have to replace that fuse .the fuse is very very cheap and you can easily get it at any electronics shop.and if still the unit does not work then there is a major fault in the power supply board and should be taken to the service center for diagnosing the fault that it is repairable or not.but i hope the above information provided will definately help you to solve your problem.
Oct 04, 2008 | Sony KV-32XBR85 TV
Tv on standby wont turn on either by remote or buttons on tv
Its not the remote but the set itself, Have it looked at and get an estimate for repair
Dec 05, 2012 | LG MKJ32022813 Remote Control
Change battery and see. Look for any jammed buttons on the remote and/or on the control panel of TV. If you have removed the plug, when the TV was in standby mode, sometimes the system controller could not have got time to reset. Try using the control panel buttons and see whether the TV responds. If not, switch it off manually, switch off power and remove plug and retry after 48 hours.
Aug 21, 2012 | Polaroid TLX-01511C LCD TV
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
How do you tune Sky+ remote into Sony KDL46W5710 Television
The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
Or try this :-
With TV and sky box on.
Press the 'TV' button on the remote.
Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
Press the 'TV' button again.
Now enter four zeros, the red light on the remote should blink twice.
Press the 'standby' button (top right).
If the TV turns off, then press 'select' and the light should blink twice again, job done.
If the TV does not turn off then press 'TV' followed by 'standby' again.
Alternate pressing 'TV' 'Standby' until the TV turns off.
When it does, finish by pressing 'Select.
Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
Dec 19, 2009 | Televison & Video
I have a toshiba tv with a broken power button
Generally the power button has to be on first to put the TV in standby mode. If you cant do this no remote can ever work. Remotes are not capable of turning on a set that has no power mechanically turned off. and that is what the master switch does. once that standby light is off it is not live and consuming power and not under the control of a remote anymore
please rate our help++++Y=Thanks for using FIXYA
Sep 25, 2009 | Sharp 27N-S100 27" TV
Wont come on
Instead of just unplugging the TV, perform a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on.  The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
Mar 25, 2009 | Beko 324250WN 28" TV
Wont come on
try pressing one of the number keys instead of the power button on the remote
Sep 06, 2007 | Beko 324250WN 28" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
