SOURCE: Tv wont turn on ???
sounds like a power regulator problem, a horizontal drive problem,or the horizontal output is shorted because of a bad flyback transformer. If your not a technician there are no user serviceable parts inside these sets and i would advise you to take the set to a pro and have it diagnosed as you could get seriously killed fooling around inside of a tv set. God Luck
SOURCE: my power light on hitachi lcd is flashing red and
Sadly to the end I can now explain the "problem" of my question by myself ...
Because I'm was not sure if I can handle the "problem" by myself I gave the Screen to a technican at our City with all the Information I found until this point (By the way my suspicion was the defect of something at the power supply unit). Two days later he gave me a call with the information about the error: An error at the power supply unit - spare parts => 50€, Work => 200€).
Unhappily im not yet got at soldering on screens, but for 250€ i would have made a good course for this (and if I can establish i will learn it).
So now again a bit more objectively:
Error / Problem:
TV - Step 1: Power Off
TV - Step 2: Stand-By
TV - Step 3: Power-On
TV - Step 4: Short flashing picture
TV - Step 5: Reverse to Step 1
Solution:
1. Find the defect Fuse/Safe/...
2. Buy the Spare part at eshop2.euras.com
3. Change the parts -> et voilá
Hopefully I could have been a little help for someone.
With kind regards,
NatureOneFreak
SOURCE: onn tv lost channel list after powercut. no remote
although initialy I was able to operate tv with sky remote, after power cut none of the codes in my freesat information pack would reconnect to tv. On the forum page one of the emails posted said they had been given the code 0527, it hadn't worked for them but it worked for me. My sky remote now operates tv. It does have an irritating habit of always switching to scart 2 at first instead of scart 1where I have freesat, I then have to use the the remote to switch to scart 1 before I can proceed any further.
I am happy enough though, I was pulling my hair out before I found your Website.
Cheers
JP
SOURCE: TV won't turn on
Im similar problen turn on of secon turn off, the probme is cap of 330mf. 200v. is open .
