Question about Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho
How to set timer on malibu box
I have 4 tabs 2 orange and two black. How do I set them?
  • Craig Butler
    Craig Butler May 11, 2010
    The orange is for the 'on' time setting. Slip it on the timer dial for the time you want to come on.. The shaded times are PM. Set the black for the time you want to go off, just slip it on the dial over the edge.
    President:
  • 1,714 Answers
Also, make sure to set the dial for the correct time of day.
Posted on Jul 25, 2009
Timer setting issues
Copy following links to help identify which Malibu timer, and how-to set timer by experimenting with features:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://waterheatertimer.org/How-to-set-timers.html
Add comment for more help.
Mar 18, 2013 | Malibu ML200RTW - Low Voltage Power Pack...
How do I set the timer with the two pins
The pin are probably trippers?
http://waterheatertimer.org/images/ML-Power-Pack-trippers-500.jpg
The trippers are red and black: black for ON and red for OFF.
Open following link for illustration of tripper install, and troubleshoot that walks through steps needed to operate and set timer, and keep timer working for many years.
Aug 10, 2011 | Intermatic Inc. ML121RT Malibu Low Voltage...
How do you set lighting to turn on and off throughout the day?
You posted under Malibu power pack.
If you have analog dial that rotates as time passes, then setting on-off times is accomplished by using black and red tripper.
Usually the timer comes with 2 red ON trippers and 2 black OFF trippers.
Place trippers on outer edge of dial and then set timer according to instruction manual.
If you need more trippers, they can be ordered
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Open following link if you need instruction manuals or troubleshoot steps for setting up power pack.
Add a comment with exact model number if you want more detailed instructions, and add your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 05, 2011 | Malibu ML200RT - Low Voltage Power Pack...
I want to replace the cord/plug is it easy?
Malibu power packs are 1-piece units that can't be taken apart.
However you can cut off the cord and leave about 4-6" of cord sticking out, and then splice into the cord that's sticking out.
Usually I buy heavy orange or black extension cord with male-female plugs on each end.
I cut off female end and use that end to splice into the cord that's sticking out.
How to splice wire.
Use knife and slice down the cord lengthwise... just cut through the outer plastic covering.
Pull the outer cover cover back to reveal black and white wires.
Cut off extra cover.
Cut back insulation on each black and white wire.
Now you have 2 black wires and 2 white wires/
Twist together the copper wire on whites and cover with plastic electrician tape.
Do the same with copper wires on blacks.
Now the blacks are joined/ and whites are joined, and each has tape over copper wire.
Wrap black tape around both sets of wires until all the black and white is covered with several wraps of tape.
That's it. Plug it in.
Nov 23, 2010 | Intermatic Malibu 300W Power Pack...
Wiring program timer switch model t1905 intermatic
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} See timer manual at Intermatic: click on T1905 to see pdf manual:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial%20with%20skipper.aspx
T1905 has 4 screws: NO normally open > NC normally closed > COM > Clock
NO screw is on left
NC screw is 2nd from left
COM is 2nd from right
Clock is on right
A) How to wire t1905 for 125V
You will have four wires >> a Black and White from breaker box; and a Black and White to load
1) Black hot wire from breaker connects to COM
2) White neutral wire from breaker box connects to Clock
3) White neutral wire to load connects to Clock
4) Black wire to load connects to NO -or- NC screw [one of these screws will have no wire attached]
NO turns 'off' with times set on timer
NC screw turns 'on' with times set on timer
If you want your load to turn 'on' when timer clicks 'on' then connect Black wire to NC screw
B) How to wire t1905 for 240V
You will have four wires >> 2 hot wires from breaker box; and 2 hot wires to load. These wires might be Black and White or Black and Red
2) Red or White hot wire from breaker box connects to Clock
3) Red or White hot wire to load connects to Clock
4) Black hot wire to load connects to NO -or- NC screw [one of these screws will have no wire attached]
If you want your load to turn 'on' when timer clicks 'on' then connect black wire to NC screw
Sep 10, 2010 | Intermatic Timer T1905 24 Hour Dial 120V...
How do I set the timer for the malibupower pack
set the dial to the corect time by turning the dial. remove the clips by pulling straight out. reinsert clips on the desired times for on and off red on black off
May 24, 2010 | Intermatic & Malibu& 300 Watt Power/Pack...
Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho Logo
218 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
