Question about Dishwashers
How to reassemble the drain pieces - Dishwashers
Why won't the plug stay down to fill tub?
The plug is clogged with air and other debris. It has to be removed, disassembled, cleaned, reassembled and reinstalled.
May 14, 2015 | Home
Need reassembly instrucstions on American Standard ToeTap Drain
buy another one and use it as a model to put yours back together then take it back for a refund.
Dec 24, 2013 | American Standard Plumbing
Danza D495080 1 1/2" touch
I have had a problem with these and the best solution is to take it apart and clean with alcohol,then reassemble with silicone caulking on all surfaces.the leak usually is traveling down the threads.
Jan 27, 2011 | Danze 1 1/2'' Touch Down Drain DANZE...
Installation.
Get under the sink inside the cabinet to do this. First, take loose and remove the connection of the arm that goes into the drain tail piece. It is on the back side of the drain piece and connects to the rod that you pull up on the faucet when you close the drain. Next, loosen and remove the nut on the back side of the drain tail piece that holds the drain lever in place. When you remove this, it will allow the old pop up plug to be removed. You put the new pop up plug in by reversing the proceedure. Make sure the rod gets inserted into the new drain pop up and the nut is snug enough to make a water tight seal when you reassemble it. Reconnect the pull rod and you are done.
Oct 12, 2009 | Moen 103459 Drain Pop-UP Plug
Refrigerator works fine except water draining into refrigerator from freezer in the back and the freezer has water collecting and freezing in the bottom of the freezer. There is no cube maker attached,...
You will need to remove the small cover on the top of the large piece mounted to the top of the freezer . There , you will see 2 screws which need to be removed . This will allow you to remove the large piece . The piece on the rear wall can now be slid up and removed . Remove the screws holding the rear panel and remove the panel . If you have an ice maker installed , it will need to be removed . Using a hair dryer , start defrosting about in the center , just below the coils , until you see the drain hole . Use hot water to help thaw the hole . Once water runs down the hole , use a small hose inserted into the drain , and blow out any unseen or built up debris in the drain line . Reassemble in reverse order .
Oct 06, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
GE with top freezer has water accumulating in bottom of frig under the crisper drawers.
Remove the food from the freezer , then remove the icemaker , if it has one ( 2 screws ) . Remove the rear freezer panel . Useing a hair dryer , start in the middle of the drain trough , and defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water will go thru . Use a piece of tubing inserted into the hole , and blow thru , to remove any debris accumulated in drain line .Remove any excess ice from trough . Reassemble freezer .
Aug 27, 2009 | GE Refrigerators
Bosch dishwasher wont drain. At end of cycle is full of cloudy water.
It is possible if you have broken a glass recently that the piece of glass has made its way to the drain pump impeller. You need to remove bottom basket. Remove the filter strainer clamp by rotating CCW. There may be another round filter under the strainer (depending on model). Then with a torque screwdriver remove one screw which holds the plastic pump cover on. Remove the pump cover and pay close attention to the pump impeller. Does it rotate by finger movement? If not it could be jamed with a piece of broken glass. You must remove any obstruction to allow the impeller to turn. I usually force a paper towel piece (half piece while rotating the impeller by finger to allow the paper towel to bring up any obstruction below the impeller) Reassemble the cover and filters carefully and make sure the final strainer clamp aligns correctly with its marks. This insures nothing will make its way to the impeller in future.
Regards Sam
Jun 15, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Dishwasher won't drain
The problem is probably a simple one to fix. Remove the panel on the lower front of the dishwasher and disconnect the drain hose. Check in the hose for debris, like pieces of a broken plate.
Next remove the pump and look inside of it for pieces of debris. I am betting that you will find a chunk of glass or bone in the little pump. REassemble everything and your dishwasher should be fine.
Jan 16, 2009 | Tappan 18 in. MDR251RE Built-in Dishwasher
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
