Sometime water wills drain then its stop why - Washing Machines
2 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: water only drains sometimes
you have clog and the first place to look is at the 2 hoses that attach to your water pump.Remove both of the hoses and look inside them and inside the pump for something that is clogging it and remove the item.
Posted on May 25, 2008
Stop water collecting at the bottom of a 3046
What about the drain tube? Also, check to see if there is a rubber flap or "duckbill" valve on the drain tube. Sometimes the rubber on them gets soft and will stick, not allowing the water to drip past them.
Oct 18, 2014 | Liebherr KGT 3046 Premium
Sometimes washer will not drain completly. leaving clothes soaked after spin cycle. sometimes suds also remain.
either discharge hose is stopped up or washer drain pipe backing up or possible water pump on washer going bad but i would really lean towards the hose or drain to the washer
Jan 23, 2011 | Kenmore Washing Machines
Oe error code
"OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludgeOR "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check wiring harness
· Check water inlet valve
· Check pressure sensor switch
· Check circuit board
Feb 20, 2010 | Kenmore Elite 45986 Front Load Washer
Water isnt sucking out
code 21 means
Long Drain
if the drain time exceed eight minutes,"F 21" will be displayed, the water valve will turn off and the pump will stop running.
Press PAUSE/CANCEL to drain the machine.
The display will cleared and the machine will turne off after a maximun of eight minuts.
Was this helpful?
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
Dishes not always clean and dirty water sometimes in bottom and food stains sometimes on inside compartments is it the filter or the inlet valve?
it shouldnt be either run an empty cycle and see if the water drains out all the way something may be stopping the drain
Apr 29, 2009 | Kenmore Dishwashers
Will not fill with water goes right down the drain,works sometimes
Your drain line is too low or there is a air gap blockage.
Remove the drain line from the drain and hold it up high while filling with water and see if it fills and stops.
If so, correct the drain line problem.The drain hose should be 36 inches from the floor.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
When starting the washer, it occasionally will not fill
Check the drain hose. The open end of the pipe the hose drains into must be higher than the top of the washer's tub (usually 30 inches or so off the floor, minimum) or the water can siphon right out. The drain hose should not be a sealed connection to the drain pipe. Try to extend the drain pipe up to about 36 inches off the floor level.
Jan 10, 2009 | Whirlpool Washing Machines
Water only drains sometimes
May 25, 2008 | Tecnik TKL9260 Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
