Question about RCA L42WD22 42 in. LCD Television
I have the exact problem with my L42WD22 RCA LCD 42"
I was watching a movie then suddenly the speakers went out, all the inputs stopped working, the rf receiver is working fine only with antena but will not take vcr or converter boxes, the only thing that is working is the vga that I use for my computer. there is immage but not sound same for digital channels. where can I buy that Fuse that went out? any help please.
How to reset rca tv
Hmmm, if you're using an antenna then go into the menu on the TV and hit the Scan for channels button. If it's a Cable box then make sure it is connected correctly and on the right input.
Aug 22, 2014 | RCA L42WD22 42 in. LCD Television
RCA LCD TV (L42WD22yx6)
Look to see if those inputs in the on screen menu show or not---locked out maybe? Someone using just the other inputs may have disabled them.
Aug 29, 2012 | RCA L42WD22 42 in. LCD Television
SOUND BUT NO PICTURE
The two long LCD inverter boards are dead.Replaced the 2 long inverter boards will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy the 2 long board LCD inverter boards for the replacement.
Jun 07, 2010 | RCA L42WD22 42 in. LCD Television
42 inch lcd with blinking red light
I just fixed mine, I am not exactly sure what did it, but I held the power button down while pushing and holding each button for a few seconds after going through each button I unplugged power cable and then plugged it back in and it powered it up and it worked
May 21, 2010 | RCA L42WD22 42 in. LCD Television
I have no sound
the only way to repair this is to replace the audio circuit.
i dont have you model so i cant provide part # also note the version tv makes a difference
Apr 27, 2010 | RCA L42WD22 42 in. LCD Television
42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Dec 05, 2009 | RCA L42WD22 42 in. LCD Television
Lost volume on 42" HD flat screen
These some use an EPROM IC pre-programmed, and like the pre-RCA, we went through many of these chips which just plug in and out, and sell wholesale from Main Electronic's in Vancouver BC Canada for $5.89 APPROX
Robert!
Oct 02, 2009 | RCA L42WD22 42 in. LCD Television
TV has no sound
First try resetting by unplugging totally from the AC, then reconnect and try again. if still no audio, check all inputs to make sure its not a bad cable/sat box , next check for a speaker switch either on the back of the Tv or in the menu. make sure the cable box and TV is not in SAP second audio program mode. if these all fail then you make need the audio IC replaced on the main board
Aug 12, 2009 | RCA L42WD22 42 in. LCD Television
Unusable Signal
Hello Mike:
The issue that you are having is with your small signal board and it needs to be replaced, it sounds like the microprocessor on that board is getting locked up.
Aug 19, 2008 | RCA L42WD22 42 in. LCD Television
RCA L42WD22 42 in. LCD Television Logo
324 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
