Question about Electrolux Vacuums
Electrolux vacuum cleaner, 1600W, 4600. How do I open the cable self roller in order to replace the cable?
  • 1673 Answers
SOURCE: Electrolux 5500
Depends on which model you have, but most of them you take off the center section, then you cab get to the 2 screws on top , and there is a screw on the bottom, then the back end will pull off. But I wouldn't try taking the cord reel apart, if that spring lets go while you are doing that, it could be dangerous. Also make sure that it isn't plugged in.
Posted on Jan 06, 2008
  • 1673 Answers
SOURCE: Electrolux diagrams and schematics
Sorry, I don't, but you cn look on line or phone book for Aerus Electrolux. But if they will ive you any info, I don't know. Sorry I couldn't help you out.
Posted on Jun 17, 2008
  • 276 Answers
SOURCE: vacuum cleaner won't go - missing a step
In between the filters there's an access panel that can be removed - there may be a blockage there. You should also check your hose for a blockage.
Otherwise you may need to take it to your local Electrolux Service Center. There may be a problem with the pressure board. The machines have a 2 year warranty, not sure what it'd be in your neck of the woods.
Posted on Apr 03, 2009
  • 70 Answers
SOURCE: How to open the vacuum cleaner to replace the bag?
pust the button on top flap will open.
Posted on Jun 22, 2009
  • 84 Answers
SOURCE: vacuum roller stops turning
with cleaner plugged in and turned on, push the little reset button on the side of the lower base of vac. Remember that the brush will not turn in the upright position. release your handle and you should be in business. hope this helps. please let us know. thanks renevacdoc
Posted on Jul 24, 2009
Problem with Electrolux Vacuum Cleaner, MDL EL8501A. Brush Roller will not turn
try pushing the reset button..its a little red usually located on the right side of the nozzle cover..
May 27, 2014 | Electrolux Versatility Bagless Upright...
Vacuum attachment problem
The roller brush assembly has to most likely be replaced or at least cleaned and lubed but better off just to replace it.
With 30 yrs. experience dealing almost exclusively with the original Electrolux, I have a legitimate store front business and do service by mail at a reasonable cost if interested.
Hope that helps! Mick
Feb 01, 2014 | Electrolux Sidekick Ii Upholstery Power...
How to repair roller on Vacuum cleaner
it migh be the belt.stretched and hardened from heat replace and try again
Feb 02, 2012 | Electrolux Vacuums
I am trying to get a user manual for an Electrolux Vitesse 1600 upright vacuum cleaner for my mother in law. Thanks
I've been trying to get a manual for my mother in law for years ;)
You didn't specify a model number so I'm not sure this is the correct manual, but it is for an Electrolux Vitesse 1600w upright. This manual is for model number Z4703AZ:
Click the link and the file will open. You can then view, save and/or print the manual. If you are unable to open the file, you may also need to download Adobe Reader:
If you have a different model, please post back with your correct model number and I will provide a link for the correct manual:
Please rate this solution if you find it helpful. Thank you.
Nov 03, 2010 | Vacuums
What charge for this service?
Actually there are no hidden screws on your Electrolux Epic model. This is the newer plastic body canister made by Aerus Electrolux. In order to open the vacuum cleaner to inspect the motor, first open the vacuum bag door and remove the vacuum bag. After the vacuum bag has been removed, keep the vacuum bag door open.
The two rubber furniture guards on both sides of the vacuum cleaner are actually what are holding the top housing and the bottom housing together. You'll need to slide both of these rubber furniture guards off in order to open the rest of the vacuum cleaner. They slide forward towards the vacuum bag housing which is why the door needs to be open.
In order to get these slides started, it's sometimes necessary to put a flat head screwdriver in between the back of the furniture guard and the start of the cord reel housing. Right after the rubber starts behind the word Electrolux. Fit a flat head screw driver in this gap, and it's sometimes easier to use a hammer, and hit the screw driver that's on the furniture guard facing the front of the vacuum.
With a little perseverance, you should be able to get the slide started, and when the slide starts to come out past the vacuum bag housing, simply grab the end of it with a pair of pliers, and pull the rest of it out of the vacuum.
Do this on both sides of the vacuum, and you'll be able to separate the two housings, and get access into the motor compartment.
If you have any problems, or would like me to take a few pictures of this being done, I'd be happy to do so. Please just rate my repair as helpful if you found this advice useful. I really do appreciate this.
Thank you,
Chris J.
Apr 07, 2010 | Electrolux Epic 6500 Vacuum
Electrolux Harmony Not working
maybe it is clogged. does the light go out if you turn it on with no bag?(for testing)
is the roller spinning?
Jan 07, 2010 | Electrolux Harmony Canister Vacuum -...
Electrolux z4494 vacuum cleaner mains cable wont stay out
Opened up case as follows:
- Open lid of bag chamber. Remove lid by gentry prising the hinge arms slightly further apart so the hing unclips from the body.
2 deeply recessed screws now accessible at rear edge of bag chamber - undo.
Prise out large button of on/off switch to reveal another screw - undo
Prise out large button of cable retract to reveal another screw - undo.
Cover now lifts off.
Inside I found the brake wheel had fallen out of its plastic bracket. The plastic bracket is hinged, and moved my pressing one end with the big button, which lifts the wheel away from the cable drum. Gently prised the bracket arms apart and put the brake wheel back in.
Solved it - but don't know why it happened, or whether it is likely to happen again.
Sep 01, 2009 | Electrolux Vacuums
I have a 15 yr old electrolux genesis upright vacuum cleaner that I can't get the roller out, to replace the belt.
There are two small screws at the end of the brush roll on some of these. There is a bearing block recessed into the housing at a slight angle to help tension the belt, so it comes out at an angle as well. It often fills with grit and you must clean the grit out carefully without damaging the blocks or housing. Sometimes WD 40 helps is the area has any rust build up. Then work a large screwdriver under one end the brush for leverage being CAREFUL not to damage the brush housing. Do not soak with WD40 as it will also get into the brush roll bearings
Jun 09, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Replace the belt
on the bottom there is a few screws remove cover and there is a roller brush there and the rest should be self explanitory
Oct 16, 2007 | Hoover U5227-930 Elite Upright Vacuum
Vacuums Logo
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
