Question about The Office Equipment & Supplies
How to access the cable roller - The Office Equipment & Supplies
How do I fix a Canon MP460 printer that feeds multiple sheets at a time, even for a one-page document, causing a paper jam?
Assumed you have cleaned out the feeding slot and sprockets that turn the feeder wheels. Often there's some piece of paper or gunk. One option that likely applies to most printers -- from another HP online source: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00190540&cc=us&dlc=en&lc=en
  1. Look for paper that might have jammed inside the product. Use a flashlight to carefully view the areas around the rollers. Remove all traces of paper found.
  2. Wipe the rubber paper-feed rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers up carefully to clean all the way around.
  1. Look for the paper pick roller farther inside the rear access area. The paper pick roller
    IMPORTANT : The paper pick roller is a bit more difficult to reach; however, it is the most important part to clean. Make sure to clean it thoroughly. If this roller is not clean, the issue will likely continue.
  2. Clean the paper pick roller with a cotton swab moistened with distilled or bottled water. Apply a moderate amount of pressure to make sure that you remove all debris. Clean the roller thoroughly all the way around. Figure 8: Clean the paper pick roller
    [img border="0" src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/855/c01996641.gif" alt="Photo of cleaning the paper pick roller." title="Photo of cleaning the paper pick roller.">
  3. Make sure that the rollers on the rear access door or duplexer are clean and in good condition. If any are missing, stuck, or loose, replace the rear access door or duplexer with a new one. Figure 9: Rear access door rollers
    [img border="0" src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/968/c01977887.gif" alt="Graphic of the rear access door and paper rollers" title="Graphic of the rear access door and paper rollers">
  4. Allow the rollers to dry completely, and then replace the rear access door or duplexer. Slide the rear access door or duplexer into place, and then gently push it in until it clicks or snaps into place.
Jul 29, 2014 | Canon PIXMA MP460 All-In-One InkJet...
E3 message on my canon printer
E3 error stands for paper jam. Unplug the printer completely from all cables. Lift it up, turn it upside down and shake it a bit to see if anything comes loose. Check the rear access and front access using a flashlight to look for any tiny paper scraps or anything else that could be hard to see. Try forcing a very thick piece of paper into the rollers to see if it dislodges anything. Finally try using a dampened lint free cloth to clean the rollers in the printer.
In case this won't help, then it sounds like a hardware damage. Probably a damaged roller.
Lucas
Jul 11, 2011 | Canon MP140 PHOTO AIO All-In-One InkJet...
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
My printer says it is out of paper when there is paper in it & the is an E where it says copies.
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water. NOTE: Distilled, filtered, or bottled water is recommended for cleaning the rollers. Tap water might contain contaminants that can damage the rollers.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Nov 19, 2010 | HP PSC 1410v All-in-One Printer
Says its out of paper, I put paper in it but when I open the folder to view printers, it says it is still out of paper
Hi!
Please clean the rollers of the printer this problem is caused by dirty rollers....
Follow these steps to clean the paper rollers.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Remove the rear access door.Different models have different rear access doors. Some have one release tab, some have two release tabs, some have a knob to turn, and some have in-tray catches. Some also have automatic two-sided printing accessories (duplexers). Release the rear access door or duplexer as necessary, and then remove it to access the paper rollers for cleaning. Product with one rear access door release tab Product with two rear access door release tabs c01963694.gif c00104514.gif Product with a rear access door release knob Product with in-tray catches c01964197.gif c02297019.gif Product with a duplexer
  4. Wipe each paper roller with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers upward carefully to clean all the way around. Figure 1: Paper rollersc01438859.gif
  5. Allow the rollers to dry completely, and then replace the rear access door or duplexer.Slide the rear access door or duplexer into place, and then gently push it in until it clicks or snaps into place.
  6. Reconnect the power cord to the rear of the product.
  7. Try printing again.
Aug 21, 2010 | HP Deskjet D4160 InkJet Photo Printer
I am receiving coof0401 error code when powering on.
  • In order to resolve this error, follow the steps below:
  • Check the paper feed rollers:
  • Remove the power cable from the rear of the unit.
  • Open the rear access door.
  • Rotate the paper feed rollers in an upward direction.
  • Reinstall the rear access door.
  • If the error persists, go on with Step 2.
  • Perform a power cycle:
  • Verify that the unit is powered on.
  • Remove the power cable from the rear of the unit and wait 20 seconds.
  • Press and hold the POWER button and insert the power cable.
  • If the error persists, go on with Step 3.
  • Perform a semi-full reset:
  • Unplug the power cord.
  • Press and hold # and 6 simultaneously while plugging in the power cord.
  • Turn on the unit.
  • Semi-full reset will do the following:
  • Change the user settings to the factory defaults.
  • Fax logs.
  • Fax headers.
  • Fax speed dial information.
Please rate my response!!!
Jan 30, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
Paper not feeding not catching on the wheels
-Remove the paper from the paper trays.
-Fan the stack of paper.
-Turn off your printer.
-Remove the power cable of the printer
-Lift the main tray, then remove foreign objects or debris.
-Remove the rear access(back door) cover from your printer, then check for foreign debris the remove it
-Clean the rollers of the printer using a lint-free cloth with small amount of water
-let the rollers dry
-Reinsert the rear access door (back door) cover
-Fan the paper and put it on your paper tray
-Plug the power cable., wait for the printer to initialize
-Do a test Print., If its still not feeding please download your latest Firmware at kodak.com/go/downloads
Now if all the troubleshooting did not solve the issue please call kodak for service and repair Toll Free 1 800 421 6699. GudlucK
Nov 03, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Paper feed not working properly
1. first check to see if there is any bits and pieces of paper in any place in the paper carriage -- look very carefully in front access and rear access
2. if this is not the problem, then disconnect printer from computer -- turn off printer, unplug power cord, unplug printer cable from printer
3. gain access to paper roller assembly, usually in rear
4. using lint free cloth, dampened with distilled water clean rollers -- read manual to determine direction of rotation (usually clockwise)
5. keep rotating rollers until all is wiped clean of paper dust
6. reassumble and try a test print as your printer manual directs
Apr 22, 2009 | Office Equipment & Supplies
My Printer Is Printing Wonky Why?
IC
Clean the paper rollers Follow these steps to clean the paper rollers.
  1. Turn the All-in-One off.
  2. Unplug the power cable from the back of the All-in-One, and then unplug the power cable from the wall outlet or power strip assembly.
  3. Use a lint-free cloth lightly moistened with water to clean the paper rollers. NOTE: Purified or distilled water is recommended for cleaning the rollers.
  4. Depending on the model of the All-in-One, use the images below to find and access the paper rollers.
Follow the steps on this HP link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02063&cc=us&lc=en&dlc=en&product=3301296
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 07, 2009 | HP Officejet J5780 All-In-One InkJet...
Transfer roller usage message on Phaser 7700. replaced..still wont print
I found the answer here: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
Resetting Transfer Roller Life
  • Resetting the transfer roller life is to be performed only if the Transfer Roller Assembly was defective and or the assembly is replaced before an end of life or near end of life message. Not to extend the life of the assembly. Doing so may cause premature failure of other internal printer components.
  • The printer will prompt the user to reset the life counts if the assembly is replaced after receiving a Replace Transfer Roller or Replace Transfer Roller Soon message.
note_image33x30.gif    Note: If the main Menu does not appear on the front panel screen and only Replace Transfer Roller is displayed, there may be a print job that is either processing or currently printing. Try the following steps to clear the print jobs and reset the Transfer Roller life:
  1. Press the cancel button several times to flush processing jobs from the printer.
  2. If you do not receive access to the front panel menu by doing this, power off the printer and disconnect Ethernet, parallel or USB cable from the printer.
  3. Turn the printer back on, and while it is powering up, immediately start pushing the cancel key repeatedly until you receive access to the front panel menu.
  4. If the printer menu appears on the front panel screen, follow the instructions below to reset the Transfer Roller life if the printer did not prompt you to reset it:
  1. With Menus highlighted press OK.
  2. Press the Down Arrow and scroll to Supplies Info Menu.
  3. Press OK.
  4. Press the Down Arrow and scroll to Exit at the bottom of the menu tree.
  5. Now scroll up to Reset Transfer Roller Life.
  6. Press OK.
  7. Reset Transfer Roller NOW is displayed.
  8. Press OK to reset the transfer roller life.
Sep 30, 2008 | Xerox Phaser 7700 Laser Printer
29 people viewed this question
Top The Office Equipment & Supplies Experts
Victorman
Victorman
micky dee
fhonwizards
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
