Question about Amana Kitchen Ranges
How old is appliance that i have amana gas range
    Top Expert:
  • Amana Master
  • 12,744 Answers
Didnt specify make or model --generic answer--look up manufacturing tag either inside door or at back cover for information on range
Posted on Apr 29, 2017
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
I need to replace one of the valves for the burners on the cook top. Where can I get one
Looks like your range uses 2 different valves. The large burners use part #317227701 which is no longer available. Small burners use part #R0150174 which can be ordered from Marcone Appliance Parts. If your problem is with one of the large burner valves, you might be able to order one for the smaller burner valves and use the old orifice.
Jan 13, 2011 | Amana RanARG7302 Gas Kitchen Range
How do i remove top of my amana gas stove
Most range tops for gas appliance can be lifted up by hand.
You may have a set of screws located just under the top just above the oven door. You should open your oven door and look up at the bottom of the range top to see if there are in fact any screws, if so remove them then lift.
If no screws you may need a small flat screwdriver to help lift the top. It does have a couple of snap clips that will hold it firm but they are just to hold it from moving during normal use.
Remember to remove your burner grates first.
Aug 07, 2010 | Amana RanARG7302 Gas Kitchen Range
It's probably not quite as easy as everyone says. Most gas appliances use a different control valve for LP (propane) and natural gas. You most likely will have to eplace the control valve with an LP one. I would contact Amana to see if they offer a conversion kit -- it would probably come with detailed instructions.
Nov 17, 2009 | Amana ACS3350 Gas Kitchen Range
Oven not lighting
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
May 06, 2009 | Amana ACF3325AS Dual Fuel (Electric and...
AMANA acs3350AS
Here are your part numbers:
Control: 31944801
Overlay: 32061901B
There are several online sources such as or just search appliance parts and you can compare prices if you like or you might even call an appliance store to see if they can order them for you. When you decide where to buy use those numbers and you you will get what you need to fix your range. Good luck.
Jan 06, 2009 | Amana ACS3350AS Gas Kitchen Range
Kitchen Ranges Logo
32 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
