Question about Tablets & eReaders
I can't charge my Simban 10" Tablet out of the box!! Charger and cable is ok; reset has no effect also...
3 Suggested Answers
99rannellis
  • 12495 Answers
SOURCE: Neither port works to charge my prestige elite 10 tablet (wall charger or USB to computer) and the metal tongue inside main charger port is loose/broken &
Your tablet's port is broken or malfunctioning. It probably needs to be replaced.
Posted on Mar 05, 2016
  • 45018 Answers
SOURCE: My Samsung galaxy pro tablet SM-T520 will not keep charge it charge s 100 then after 10 min goes flat have bought new charger
Battery defective
Posted on Feb 28, 2017
I have a tablet that I can get to work
1) Look up the manual for it by brand and model number.
2) If there is a quick start guide, read that.
3) If upon following the instructions, the tablet does not start, put it on a charger.
4) If upon putting it on a charger, there is no indication that it is charging, check to see that the charger is plugged into an active wall socket and that the charging cable is undamaged (possibly by swapping it out with another cord).
5) Phones and tablets can frequently undergo a "hard reset" which will return the device to the original factory setting, as if it had just come out of the box. Examine the downloaded manual for "reset" or hard reset. You might perform that.
6) No battery has been removed, right?
7) Check support on the manufacturer's website.
Jul 31, 2017 | Tablets & eReaders
The charge dock on tablet broke so we can not charge tablet can it be fixed? We just got it this October.
Juello. Did some research on your tablet at Amazon, (http://amzn.to/1xWx6S5) and see that they also have an AC charger (AC charger adapter with a 3.5mm power jack and delivering 5VDC 2A). Available for $5: iRulu Black AC Home Wall Adapter Cable Charger for Tablet PC 5V 2000mAh or a there's a nice replacement KB and cover: iRulu New Portable 10 1 10 5 Android Tablet USB Keyboard Case Black . I would guess the connector snapped off inside the tablet, so you will have to remove it with some tweezers. If the pin for the AC adapter broke off inside the tablet, that's a problem, but most everything can be charged from the USB port too see this website:
How To Charge Samsung Galaxy Tab 2 Via USB Port On Computer Laptop PCNEXUS (Samsung used as an example). GL
Jan 08, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
How do I load APS to SD card, my Simban 100 will not load anything beyond 8gb internal memory.
one way that always works though a few steps.
get an sim adapter for the sd card for your computer they are cheap to buy.
connect cable to your simban 100 an copy what you want off of it too.
now put all you want on the sim connected to your computer with sim adapter.
when finished you now have any apps you want on the card. generally.
if you want to load apps from the sim you have to go to security setting in tablet n set it to allow that.
Jan 05, 2015 | Tablets & eReaders
My 7 inch Samsung galaxy tablet will not come on.
have you tried turning off tablet with charger plugged in and letting it charge up. You should see a battery symbol come onto the screen with a pulsing level indicating the battery is being charged. hold in power till unit turns off then plug in charger cable into tablet and switch on charger at power point . Do not try and push power switch to power up tablet see if screen indicates charging is occurring. I have experienced this exact problem on a samsung tablet !
May 03, 2014 | Tablets & eReaders
My nabi tablet is charged but wont turn on
Try a different charger first, as it maybe faulty. If not the battery maybe faulty and I would purchase a new one.
Mar 16, 2014 | Nabi 2
Cant get my samsung tablet to turn on
Your tablet's battery is probably dead. This may be because you have a bad battery, a bad charger, or a bad charging cable. Try using a different cable first and let it charge for a few hours - even if it doesn't look like it is charging.
If the new cable doesn't do it, try using a different charger. Samsung devices are picky about what charger you use, so try to use one made for your tablet. If you don't have another charger, plug it into a PC's USB port with the PC turned on. Leave them on and plugged in over night. That should trickle charge your tablet.
If neither of those work, try holding down the power and the Volume Up buttons. Keep them both pressed until the Samsung logo/boot screen comes up - should only be a couple seconds. Once the logo comes up release the power button but keep holding the Volume Up button. That will boot you into Recovery Mode. If that comes up, it means you've got power and your tablet isn't broken, but there is something wrong with the Android OS that is keeping your tablet from powering up normally. Use the Volume Up and Down buttons to move the selection highlight to the Factory Reset option. This will wipe all the info off your tablet and put it back into a "brand new just out of the box" state. You'll lose your information on the tablet, but this should fix the boot problem. Press the power button to chose the Factory Reset option. It will take a few minutes. Once it says that it is done, select the Reboot or Restart option. It should reboot. This boot will take longer than normal, since its wiping things out. But not more than a few minutes.
Jan 02, 2014 | Samsung Galaxy Tab Tablet PC
How do i fix my tablet?
First off I was ask do you know if the charger is good? If it uses a USB connector to charge and you have another device with a charger, try swapping it out. Look on the tablet charger for the Volts (V) and the Amps (A) it will probably be 5V and 1-2A if you have a charger with a fairly close rating it should charge the tablet. You may also need to hold the reset button down for up to 20 seconds.
Jun 18, 2013 | Tablets & eReaders
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Mar 13, 2017 | Ainol 10" Novo 10 Hero 16GB Dual Core IPS...
My Galaxy tab 7.7 wont charge, I tried to charge it yesterday when the battery was still 50% charged but now it is down to 15% and my tab won't charged. I am using the original charger, please help!...
my mama said that mayb ur need a new charger cuz Samsung is sending me a new 1 and I think that\'s y. I hav a 7 inch tab 2 n I love it but it stop charging so I don\'t no whats wrong but im getting a new charger so its all good and guppy now :) ill keep u updayted cuz I think its the chargers falt not the tablets!! idk if not then ill just reset my tab and cry my eyes out cuz that sucks big time I meen really who wanna reset there tablet? not mee! but what the hell..mayb a new charger will help the little baby...
Jan 23, 2013 | Samsung Galaxy Tab 7.7 P6800 3G 16GB...
Tablets & eReaders Logo
44 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
