Question about Get Home Security
Safe door opened and stayed in open position can t get it to lock again
SOURCE: door lock on 2005 -3500 truck
Yes Admin,
This is what I found out. The problem was with the power lock portion of the part (siezed). It is also sealed and unserviceable. The good news is that the part was in stock at the dealer for around 65.00. Actually pretty amazing considering how many parts there are to the device. After disassembling the door three times (once to diagnose, once to take apart and disable the power lock function, and one last time to swap out mechanism) I became fairly quick at it. If you have this problem, just go buy the part and don't mess around. Oh yeah-you'll need a torx bit to get started.....
Posted on Mar 25, 2009
SOURCE: gordon item#45891 digital safe, lost code the door is open
there is red button on the inside of the door (hinge side) press this , then key in a new code
Posted on Oct 10, 2009
  • 3600 Answers
SOURCE: Door locked on safe
Brian We can't give advise on the safe but you can call the manufacture of the safe and if you have registered it they will help you otherwise federal law requires a lock smith to identify you and your information and your ownership of the safe before they will unlock it for you. This is to protect you or the safe owner and the lock smith from being sued and losing his licence.. There should be a sticker on the safe with a 800 number for you to call to get help. But you must have registered it first. They may have a way to verify it some other way but am not sure.
Posted on Nov 22, 2009
  • 1810 Answers
SOURCE: 1995 Chev Suburban rear door latch stuck in locked position
sounds like you lached the door
use a screw driver or some such tool
lift the outer handle and slip your tool in the middle of the lock hole in the door flip the lach open wile holding handle up
Posted on Dec 31, 2009
SOURCE: 2006 325 i door locks not working driver door will
I had a very similar situation. Was very annoying not being able to unlock or lock doors from pannel control nor from remote.
Only driver door can be opened with manual key.
Solution: One of the 15 amp purple fuses was blown. Fuses are located inside glove compartment, the interior end has to be removed releasing the two locks.
Use a light and the red tool located on the panel to remove fuses.
Posted on Oct 18, 2010
Testimonial: "very helpful thanks doors work now! "
How do I remove oven door
open the oven door all the way and look down at the hinges. there is a little locking clip that you swing into position that locks the hinge from closing. it might be stiff and need some cleaning depending on how old and dirty your oven is. Also you might have to push down on the oven door to make the hinge open fully to get the locking tabs into place. making shore that the locking clips stay in place and hold open the hinge as you lift the oven door slowly towards its closing position and you will see the whole hinge lift up from inside the oven cabinet and the door will just lift out. be careful not to catch your fingers. make sure the looking tabs stay in place during removal as the hinge is very hard to get back into this position again. re fitting is the reversal making sure that you have pushed the base of the door all the way back into the cabinet and push down on the as to open it to release the tabs.
Sep 23, 2016 | Ovens
We have just moved countries and left the safe locked open whilst moving. We are now can't get the door bolts to open? Is there a way to reset the combination with the door open and the bolts in the locked...
I'm afraid the electronics thinks the door id locked, on the other hand in most safes you can access the logic in the door when the door is open. Not knowing what brand and model you own, it is impossible for anyone to give a better advice.
Mar 03, 2015 | Locks & Locksmithing
I can't get the lock to disengage so now it's locked...open!!
You must enter the code to unlock the safe, just as if the door was shut. The safe does not know the door is open and you just need to shut it.
If you have entered the code and it unlocks properly but you still can't disengage the bars, take the panel off the inside of the door and inspect to see what is causing the problem.
Jan 10, 2014 | Mesa Safes MFL2014E Safe Depository Safe...
How do i change the code on a s25e digital safe i cant find the book
if its like my old woolworths one, open the door and press a red reset button on the inside of the door, close the door and dont lock, put in the 4 numbers u wish a press a A button on the keypad, or whatever ur enter button is, then lock it, then press the 4 numbers again and the A button or enter, a light should stay on and unlock :)
Feb 21, 2011 | Safe International Electronic Gun Safe...
My safe wont open,.
Got dynamite? Just kidding. have you tried to close it and lock the handle all the way in the up position. and then try to open it up again.
Good luck
Nov 18, 2009 | Sentry Fire Safe - Safe - DS0200
Cant get back door to stay closed . The lock is stuck in locked position I think and the door is open. When I go to close it, it is'nt staying closed. Had to duck tape it to stay closed. LOL! I keep...
It sounds to me ( correct me if I'm wrong ) like the door latch on the side vertical edge of the door is in the LOCKED POSITION. In order to unlock it perform the following. First electrically with the LOCK button UNLOCK the locks. Now with one hand hold the OUTSIDE DOOR HANDLE IN THE OPEN POSITION, while at the same time FLIPPING OPEN THE LATCH. All Done . Now you can close the door. Hope this helps
Jun 27, 2009 | 1997 Chevrolet Lumina
I cannot close my safe's door
This is locked in the open position.
You will need to go through the opening procedure to open the mechanism. You will then be able to close the door before locking it again securely.
May 03, 2008 | Sentry Fireproof Safe
Home Security Logo
Top Get Home Security Experts
ray gallant
Beniptec
Level 1 Expert
R.A. Ellis
R.A. Ellis
Are you a Get Home Security Expert? Answer questions, earn points and help others
