Question about Hotpoint Washing Machines
Hotpoint smart tech WMFUG 742 U.K. On display says code F06 and door won't open can you help please ?
gittos73
  • 244 Answers
SOURCE: Hotpoint Ultima WD71(probably the wd72 except in white)
hi there what u can do is take your drain hose and place into a bucket water will come out the door will release now check the pump and make sure that it is not blocked up with anything if it isnt check the drain pipe that is under the washer in the middle of the drum there will be water in there but check inside if anything is inside there it will slow down the empty programme and will not let the door release do u live in malta then m8 as my dad is maltease and im half
Posted on Aug 23, 2007
JR JR
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
  • 200 Answers
SOURCE: Hotpoint ultima wt741 F11 fault code
HI
There are several reasons why a Hotpoint door could be jammed shut. One of them is the part you describe which is called the ******. With some older Hotpoint models, there is a cable that runs from the door interlock to the motor. When you operate the door catch or button, this part "pecks" down onto the drive belt or the end of the armature's shaft. If the drum is moving, the ****** will slip on the rotating belt or armature and disengage the door interlock. If the drum is not moving, the ****** meets resistance and the door opens. Therefore if the ****** has come off, or is loose, it can stop the door opening. When you attempt to open the door does this part move?
Other things that can stop the door opening are -
  • A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoints - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
  • If there is water still inside the washing machine, then the door wont open either on these Hotpoint washing machines (not on some others though) If this is the case, when you try to open the door the ****** won't try to move down at all. You can open the door usually if you drain the machine. (only applicable with door interlocks that have a rubber pressure hose attached to them)
  • A faulty door interlock
  • The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunge can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thank you
Posted on Dec 06, 2008
skrbin
  • 121 Answers
SOURCE: hotpoint bwm129 washing m/c door won,t open
probably door lock-switch.
Posted on Feb 16, 2009
  • 5 Answers
SOURCE: hotpoint aquarius wf320 1200 spin
its blocked...try the waste pipe
Posted on Nov 14, 2009
My hotpoint aqualtis model number aq9f 492 u is showing f6 what does this mean
F06 Door lock fault
Issue: Washing machine door cannot be opened or closed / when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
Dec 29, 2015 | Hotpoint Washing Machines
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Indesit model iwe7125b problem f06 what does it means?
F06 : DOOR LOCK fails to close/open, door lock triac open/closed, frequency signal fault.
Action: Switch off the device. Disconnect power. Wait about 3 minutes. Open the door, then close, reconnect device to the network. Start device
Dado
Dec 20, 2014 | Indesit Washing Machines
Flashes error code F06
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its a faulty CCU that needs to be replaced. Here is the part.
Oct 19, 2012 | Sears Kenmore Elite 4.2 cu. ft. Front-Load...
My Hotpoint WMF540 (Aquarius) keeps displaying DOOR error message
I know this is an old question but for the benefit of anyone else having the problem, here's how I fixed it on our machine ( a WMF540 P (UK) R ).
Our clicked about 6 times then displayed the "door" error. The clicking noise is the solenoid inside the door interlock. The fact that it was clicking showed that it was functioning. Just as a precaution I removed and disassembled the interlock to check it and everything inside was fine.
Next, I removed the rear panel of the machine, took off the drive belt, disconnected the white plug and earth lead from the motor. Undid the two bolts holding the motor and dropped the motor out of the bottom of the machine.
The commutator was completely black. I removed the carbon brush holders and gave everything a blast of compressed air to get rid of the carbon dust. I then used a piece of very fine wet and dry abrasive paper and cleaned the commutator so that it was nice and shiny again. The brushes looked like they were on their last legs but as I didn't have any others available I just put them back.
After replacing the motor and the belt I tested the machine and it worked fine. Now I'll buy some spare brushes and replace them at some conveniente time in the future.
May 01, 2012 | Hotpoint Washing Machines
F06 error code
Hi Bunny:
F06 code will indicate a drive motor tachometer error; means the control is unable to properly detect motor speed and the machine will shut down.
If a failure occurs during high-speed spin the door will be unlocked after 3 minutes. Potential Causes:
* Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
* Check the MCU
* Check the Wire Harness
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 14, 2011 | Frigidaire GLTF2070DS Front Load Washer
My keypad won't light up when door is locked whe you push lock won't light up green
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Aug 04, 2011 | Kwikset 909 909-L03 Lifetime Polished...
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Loads interrupted
interrupted wash cycles and also give a code of F06. A service tech was supposed to be at my residence today... he did NOT show. This machine is little over a year old. Tried unplugging with no sucess. Any help would be appreciated.
Sep 15, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
108 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
