If80 51 thermostat- displaying incorrect temperature. Says 91 degrees F when it's about 72 therefore air conditioning is not switching off
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
Bad thermostat
Posted on May 02, 2017
  • Heating & Co... Master
  • 1,621 Answers
Unfortunately there is a calibration adjustment but it's not going to be that much. Sounds like a bad tstat. Either pull face off wall to stop unit or turn off at breaker until hot again temporarily. Remember to turn power off before changing tstat and take pictures or diagram of wiring. Good Luck!!
Posted on Apr 29, 2017
Testimonial: "Thank you! ??"
The temperature displayed on the front of our fridge is incorrect, How do I fix this?
possible that the rear of the fridge needs space for the condenser to get air to cool
Oct 24, 2015 | Refrigerators
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
My thermostate will not shut off when the room temperature drops to 72 degrees in which my thermostat was set at on the auto cool setting. It even continues to run and drop below 72 to 68 degrees and never...
What brand and installed in what? If a thermostat is installed on a wall that is heated by the sun it will give false temps. If it's mounted too low or high it will not be right either.
Oct 08, 2014 | Heating & Cooling
What does -AC on honeywell chronotherm III thermostat mean?
AC means "air conditioning." If the AC icon is showing on your thermostat it means that your air conditioning is activated and should come on when the temperature threshold you've set on the thermostat is reached.
For example, if you've set the temperature level to 78 degrees, when the house temperature goes above 78, usually by about two degrees, the air conditioner should cycle on to cool it back down to 78 degrees at which point it will then turn off.
This information should be in your air conditioning/heating system or thermostat owners manual. If you don't have the manual, you should contact your air conditioning dealer or your builder to secure a replacement. The manual is essential for proper operation and maintenance of your system.
May 14, 2014 | Heating & Cooling
Duo therm thermostat troubleshooting
replace thermostat or communication cable to relay module.
Jan 21, 2014 | Dometic Rooftop RV Air Conditioner
My white-rogers 1F81-261 model thermostat keeps rgoing back to a 62 degree setting after the furnace kicks on at a setting of 72 degrees. I have reset the program, but that doesen't seem to help. What can...
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set to
HEAT or COOL, momentarily press HOLD button. HOLD
will be displayed. Use UP or DOWN to adjust the temperature.
The thermostat will hold the room temperature at the
selected setting until you press RUN button to return to
program operation.
This is on page 6 of the manual
Link: Installation Instruction
Feb 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
When this thermostat is in the HOLD position, which cancels the programmed feature, I set the temperature to 72 degrees and the furnace runs until that 72 degree temperature is obtained. Now the thermostat...
If you still have the instructions for the thermostat, then it will show you how to get into the menu and set the swing on the temps. I would try to explain off the top of my head, but its actually quite a bit off numbers to remember. Hope it helps somehow.
Dec 29, 2009 | Honeywell Focus 6300B 5-2 Days...
Housesitting. RTH111B model. I cannot keep the
That is a NONprogramable T-stat. There is no program to overide, therefore there is no need for a "hold" option. To set the temp, place the switch on the side marked
COOL
OFF
HEAT
to the desired setting, and push the up down arrows on the front until the display shows 80.
The DISPLAY will revert back to the current room temperature within a few seconds, and will keep the unit on until it reaches the desired temp.
The set temperature remains at 80, it just shows the current room temp.
Aug 31, 2009 | Heating & Cooling
How to use a SUNBEAM twin window fan with
Intake brings the air outside into your room, exhaust pushes the air inside your room out.
What setting you use depends on your personal taste of temperatures and the temperature inside vs outside. If you set the thermostat to 72 degrees and it is more than that outside then I would use the exhaust setting. If you set it to 72 degrees, and it is 68 outside but 84 inside then I would set it onto intake to cool the inside air.
Jun 21, 2009 | Dryers
AC blown warm air
This one is a difficult one to say. You could have a bad ac unit on the cars engine. Also when it goes back to 72 degrees your car is just displaying the temperature inside the car one of the features of a digital adjustments on these types of cars. Also you could have a leak and therefore not getting the cold air you wanted.
Jun 17, 2009 | 2000 Mercedes-Benz CLK
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
