Question about Punch Computers & Internet
Hi,I was trying to punch my email...they say it does not match.
The letter you punch in does'nt match what comes on the paper
You are probably in the languagr mode try code "L".
Mar 09, 2012 | Lexmark Wheelwriter 10 Series II...
Punch software home design
Can you please describe your problem more clearly.
Waiting for your reply.
May 15, 2008 | Punch ! Super Home Suite (695985)
On the 87 toyota camry what are the timming belt marks and spects when youi replace the belt
Hi Rockzone, Set the the engine to Top Dead Center before removing the old belt. If you've already removed it with the timing in any other position, do the following:- Rotate the camshaft so that the drill hole through the gear, is opposite a punch match mark behind it. (The punch mark is on the front of the camshaft cap). It is advisable to use a bright light and a mirror, which you hold at an angle in front of the camshaft drive gear. Shine the light between the gear and the cylinder head. Rotate the cam until the hole aligns with the punch mark. Once aligned, then rotate the crankshaft until the 'V' cut out on the crankshaft gear aligns with the match mark arrow on the front of the oil pump housing. Make sure that the tensioner bearing is at the maximum loose setting, fit the belt. Gently release the tensioner bearing and then recheck the timing. ( Adjust if required). When correct, tighten the lock nut on the tensioner bearing. Rotate the engine, turning it with a socket spanner from the crank shaft two full revolutions, and then recheck mark alignment. When the marks align after rotation, fit back everything else. Regards Johngee10
Jul 22, 2011 | Toyota Camry Cars & Trucks
Putting a hole in a sports patch
You need a leather hole punch. It's much like a paper hole punch, but with a different cutter. You can find them at craft stores.
May 04, 2009 | Bernina 1008
Need to match DIP switchs on a universal garage door remote
I find Clicker products confusing. Might want to buy whole new replacement readio control set. how old is operator?
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Accessing email messages
if the yahoo email is adult based or relationship based usually it will be filtered out. make sure you add the email sender to your address contact list, and try again.
Oct 26, 2008 | Yahoo Mail
I would gladly try to help you, but you do not mention wich brand and model the oven is, however they all work basicaly the same:
1. Punch in cook time. 2. Punch "CONVEC" 3. Punch a temperature button 4. Punch "START"
If you give me the brand and model number I may be able to email you the instructions for fee via email.
Hope this will help you.
Eddie Rentas
Tupper Lake NY
Jun 25, 2008 | Cooktops
Computers & Internet Logo
26 people viewed this question
Top Punch Computers & Internet Experts
Lawrence Oravetz
Are you a Punch Computer and Internet Expert? Answer questions, earn points and help others
