https://www.manualslib.com > ... > LCD TV > 242T FHD
View and Download Olevia 242T FHD user manual online. 2 Series LCD HDTVs. 242T FHD lcd tv pdf manual download. Also for: 247t fhd, 252t fhd, 255t fhd.
You visited this page on 13/01/23.
try external speakers and see if it continues, if yes, need new tv, if no, then use external speakers. (you also can try unplugging from power completely and see if that resets it).
Make sure you don't have the mute feature turned on. Also, not sure about your particular model, but some of the older Olevia sets have external speakers that are mounted on the bottom of the set. The speaker wires are external and plug into a jack on the back of the set. If this is such with your set, check the speaker connections. Some TV sets also have an option which lets you disable you onboard speakers so that your audio out terminals are activated. This option is for those who choose to use their surround sound systems vs. the factory TV speakers which tend to be of cheap sound quality.
Does your TV have an Audio out? This is the only way that you can get signal to feed to your coby speakers and make sure that your coby speakers has an amplifier.
We would be happy to help you with getting your DISH Networkremote to control your Olevia TV. We're going to start by pressing and holding the TVbutton located on the top of your remote until all mode button back lights comeon, and then release. Use the number buttons to enter the codes for your Olevia TV; here are some of the codes we currently have for it: 910, 506, 578, and 506. Press the pound (#) button. To check if the code works try severaldifferent functions on the remote to make sure it will properly operate the TV.Remember that some codes may not be compatible with your equipment. If this isthe case, try the other codes listed for your Olevia TV until you findone that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang DISH Network Customer Service Representative
one way to test the audio on the tv is to connected a cable line or ant.. and see if audio comes out on the speakers of the television.. if they don't then go on the menu under audio and make sure the speakers are not turn off..
If you get audio with the ant or cable channels.. then the television speakers are on.. now you might want to try the sat receiver with different connections an example will be AV cables.. yellow, red and white.. to see if that works ? make sure the red and white are right next to the yellow input or else you wont get audio..
If you will like more help.. you could also contact this company called Amergence Technology they have trained technicians that have knowledge for Olevia products.. there number is 866-965-3842
I have a olevia tv with olevia remote, I have to type in the number to change the channel. what do i need to do to fix the problem? So i can use the tv channel changer.
