Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Ryobi ss30 weedeater not starting after repair,to the primer bulb
I just replaced the gas primer bulb it had cracked.put the new one on.and it will not start.it would run for 2 minutes before i replaced the bulb.then it would die out.so i figured i would replace spark plug. did that.and still not even trying to turn over.just wont start.iam at a loss.can anyone please help.
  • vanilla1973 Jul 25, 2009
    if it is flooded.what would be my next step?
  • 245 Answers
Follow the instructions exactly. If it won't start, take out the spark plug to see if it is wet, or dry. If it is too wet, the motor may be flooded. If it is completely dry, you have to figure out why it's not getting gas. I am assuming you are pressing the bulb the recommended number of times, and that there is gasoline in the bulb, providing some resistance to your pushes with your thumb.
Posted on Jul 25, 2009
  • Gene Tuck Jul 25, 2009
    If the spark plug is very wet, place the base of the plug against a metal part of the motor, with the sparkplug wire attached to the plug, and pull the starter rope, looking to make sure that the plug has a spark. If it doesn't, that is the problem and it may be that the breaker point gap has to be adjusted or the capacitor (condenser) has gone bad. It is not easy for folks with the typical tools of a homeowner to fix either of these problems, but it can be done. If the spark is good, pull the starter about ten times with the plug out to clear out the excess gas, put the plug back in, then try to start it. Too much gas on the plug could indicate that you are pressing the primer bulb too many times or that the fuel adjustment is set too rich.
    Dry out the plug before testing for spark.
What would be wrong with my weedeater when i press the primer bulb gas will start to come out of the gas cap ?
You could have a clogged tube from the primer into the carb, but it also sounds like the fuel tank is overfilled.
Jul 14, 2014 | Fuel Line & Primer Bulb Repair Kits 2...
179 cc powermore engine model 31as62 ee7700
this new gas plays havoc on fuel lines, you might want to replace them, the pug wire might have a bad spot in it, sparks when out but when installed fails to spark,try removing spark arrestor from muffler, try using boat gas it has no alcohol. help me help others, if this is what fixed you up, please tell me or tell me what you found was the problem. thanx Jay the pool pump motor repair guy longwood florida
Nov 11, 2013 | Fuel Line & Primer Bulb Repair Kits 2...
RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
Aug 01, 2009 | Ryobi Garden
Ryobi ss30 weedeater,if weedeater is flooded
If the spark plug is very wet, place the base of the plug against a metal part of the motor, with the sparkplug wire attached to the plug, and pull the starter rope, looking to make sure that the plug has a spark. If it doesn't, that is the problem and it may be that the breaker point gap has to be adjusted or the capacitor (condenser) has gone bad. It is not easy for folks with the typical tools of a homeowner to fix either of these problems, but it can be done. If the spark is good, pull the starter about ten times with the plug out to clear out the excess gas, dry out the plug and put it back in, then try to start it. Too much gas on the plug could indicate that you are pressing the primer bulb too many times or that the fuel adjustment is set too rich.
Jul 25, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Primer Button
This part is sold as an assembly Part# 530038874
Undo the screws holding the primer and note the fuel line location
as the new one will be identical.
Note the long and short tube connection under the primer bulb itself and the designated tube for each
Jun 04, 2009 | Garden
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
2,032 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
