Question about Troy Garden
Troy built 547cc how much Hp is that - Troy Garden
5 Suggested Answers
  • 1388 Answers
SOURCE: replace pullcord on troy built mower
Replacing the rope is not difficult but tricky. I believe that your model has a fuel tank on top of starter cover, empty fuel and remove tank to expose starter cover. Remove the starter cover and place it on your workbench with the plastic rewind spool visible and remove the old rope noting how it was tied. The rope is sold in various sizes from # 3 to # 6.5. Most mowers use a #4.5, with length of about 6 to 7 feet. You may not need this much but more is better. Now practice inserting the rope thru the hole where it comes out of the cover into the hole where it ties on the spool. Once you can do this you are ready to wind. The spool /spring winds when you pull the rope, that why it recoils when you let go of the rope. With that in mind, turn (wind) the spool in the same direction that it turns when you pull the rope. It should be getting tighter as you turn. Keep winding in the direction that it turns when you pull the rope untill it will not go anymore. It should be very tight. Now unwind one complete turn and align the hole of the spool to the hole in the housing and hold it there while you insert the rope from outside hole into the spool and tie knot. After the knot is tied slowly let rope rewind into the spool untill it stops on its own. You are done. You should have plenty of extra rope left to extend out to the handlebar. Enjoy
Posted on Jan 11, 2009
SOURCE: 5 HP troy bilt chipper sherdder will not rev up under load
Either or do one of two things if the motor runs pretty well Start the engine and run it full throttle. Once there if it has a high speed jet turn the screw in to start with until the engine stumbles a bit and then turn it back about a half turn. When you turn it in you should here the engine peak out. .If it is blowing black smoke out the exhaust it means the high speed screw is to far out so turn it in until it smooths out.If the engine smooths out then you have cured the problem. Good luck.
Posted on Mar 20, 2009
al_kupchella
  • 843 Answers
SOURCE: Troy Built 6.0 HP stored for winter. Fired up and
Most definitely. You aren't getting enough gas, probably because the float valve is gummed up. Drain the gas, put in a little carb cleaner and a little fresh gas. Fire it up. Do that a couple of time if needed, then fill tank with fresh gas. Use a gas stabilizer like Sea Foam to prevent this.
Posted on Apr 05, 2010
Testimonial: "Great Solution and response time!!!"
SOURCE: my troy built 210 6.75 hp mower self propelled mow...
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
Posted on May 30, 2010
A briggs and stratton 547cc equals what hp
CCs can't be directly correlated to HP. They are measuring different things. It depends on how the engine is tuned. You can approximate that small engines 1 HP = 30 - 32 CC, car engines are usually 1 HP = 15 - 17 CC. So, 16.5 HP or so.
Mar 22, 2017 | HP Measuring Tools & Sensors
What is the battery size for a Troy built riding mower?
call your troy built dealer and ask it depends on motor hp etc which we do not have
Sep 12, 2016 | Troy Garden
My rototiller is missing the data tag with Model and Serial No. The only id I have is the engine SN. Would like to identify engine mfg and Troy-Bilt tiller model.
Google search Troy-bilt Proline Tiller and search through the images to find the model most like yours. I believe the engine was built by Honda.
Good luck,
May 10, 2015 | Troy-Bilt Garden
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
My troy built 210 6.75 hp mower self propelled mower doesnt pull
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Apr 05, 2010 | Troy-Bilt Pony Garden Tiller
My troy bilt horse has serial number 544253, can anyone tell me what the model number is and what year it was built? Thanks
if you have a B&S engine look at the frist two numbers on the code. thats the year of the engine and more likelyof your unit, As long as the motor has'nt been replaced. I'll checked on your serial number did'nt find a model. If this is an old troy built I'll have to call tech support. also I need to know what engine 4, 4.5, 6, 7, 8, hr power, and the name of the teller. MTD now owens troy built.
Oct 17, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Garden Logo
395 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
