Question about Kitchen Ranges
How to put back glass panel on old domotec cooker hood after cleaning
5 Suggested Answers
SOURCE: Nardi FEA0614 Electric Oven
www.nardi-appliances.com
Posted on Nov 05, 2008
barkencoa
  • 3463 Answers
SOURCE: The main oven inner glass door panel has shattered
Unfortunatey, it happens quite frequently, there is no one reason for it to do so.
The only solution is to replace it.
Over a number of years use, the glass looses it's properties, and this is what can happen.
Posted on Jan 24, 2010
SOURCE: I have a Domotec Cooker Hood, the switch that
I have a Elecrolux Range Hood PLHV36W6CC and the fan switch is broken too, it just slides back and forth and it is ON.
I will check that website...Thanks
Robert
http://www.150FastGroup.com
Posted on Aug 03, 2010
emissionwiz
  • 77186 Answers
SOURCE: how do I locate the
Hello
I have never seen a ignition system powered by a battery, it is done through a solid state ignition module that creates the spark to lite the burners. I will need the manufacturer and the exact model number (located on a sticker or in the user guide booklet) of the oven to assist further. I also need to know if this is a US model. We are based in the USA so we can only access repair info for North American products in most cases.
Posted on Sep 14, 2011
AER5630BAS died
Check the fuse/ circuit breaker in the fuse box first if that's ok some electric cookers have a fuse or a fusible link inside the back panel, you will need a multimeter to test it (be careful electric cookers are dangerous to work on) if you are not familiar with them.
Apr 21, 2014 | Amana AER5630BAS AER5630BAS 4.8 cu. ft....
How do I remove glass from the door to clean it ?
They may be rivet holes. On my Zanusi the thin panel that goes across the top of the glass to hold it in just slides off forwards toward the cooker.
Then the glass slides out upwards.
Apr 15, 2012 | Zanussi ZHQ575 Electric Double Oven
I am trying to find somewhere to get spare parts (in particular the small detail brush) for this two-year-old steam cleaner. It appears that Domotec no longer have a UK distributor but I think they do...
Domotec does not exists anymore , however you can buy from www.espares.co.uk : Vax Steamer Nylon Brush (ES956244) which is similar to the one supplied with Domotec steam cleaner.
Jan 03, 2011 | Vacuums
How to replace a bulb for kd rangehood
This is for a smeg KD series, it depens on the model which lights are used.
LIGHTS REPLACEMENT:
Before performing any cleaning and/or
maintenance operation, disconnect the hood
from the mains supply.
According to the model, the hood can be equipped
with different kind of lighting such as incandescent,
halogen and neon lamps.
a) Incandescent lamps: E14 – 40W 230V lamps.
To replace them, remove the transparent fixture
from the control panel, unscrew the lamp and
screw in the new one.
b) Halogen lamps: G4, 20W - 12V lamps . To
replace the lamp, use a screwdriver to remove
the glass-supporting ring. Then remove the old
lamp and insert the new one.
Put the glass back, securing it with the ring.
c) Biax neon lamps: G23 11W lamp. Once the
fixture has been removed, remove the biax lamp
from its seat and support.
Put a new lamp in, performing the same
operations backwards.
d) Neon lamp: 15/18W neon tube. To reach the
neon tube, unscrew the glass framework screws.
Rotate the tube 90 degrees and remove the neon
lamp. Install the new neon tube and put the glass
framework back.
Hope this helps
Apr 13, 2010 | Kitchen Ranges
My oven door won't open and its not locked or on clean. what do i do
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 03, 2010 | Ovens
I have a Domotec Cooker Hood, the switch that turns on the various speeds for the fan appears broken. Is it possible to get replacement switches?
It looks like Domotec has a facility in Wiltshire. The e-mail address is service@domotec.uk.com, and the phone number is 01249813835. I couldn't find any parts dealers here in the US, but I am sure there is a local dealer in your area that either carries a direct replacement or a generic replacement that may do.
Feb 21, 2009 | Kitchen Ranges
Cooker hood not working
Check power from the wall.
Check power in the wiring coming into the hood.
Check to see wiring is not broken.
Feb 18, 2008 | Kitchen Ranges
Cooker
HI THERE SKI IS THE GLASS DOOR PANEL THE INSIDE DOOR GLASS OR THE OUTER DOOR GLASS PANEL AND IS IT THE MAIN OR TOP OVEN.
THE GLASS PANELS INTERNALLY ARE HEAT BONDED IN THE FACTORY AND CANNOT BE REPAIRED YOU WILL NEED A NEW DOOR GLASS.
IF INTERNAL ONE COME AWAY THEN U WILL HAVE TO HAVE A COMPLETE INNER PANEL.
Feb 13, 2008 | Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
