No change developer & drum how to salve bizhub 164 error code m2
pramoditman1
SOURCE: how to reset bizhub 164 code M2?
Bizhub 164 (M2) error
Posted on Aug 26, 2014
kraggarwal_k
  • 6 Answers
SOURCE: What is m2 code how cani reset in Konica Minolta
This is to display the count of the supplies life counter.
When the counter is reached to 0 life 1 will be detected and maintenance call M2 will be appeared.
The initial value is 40,000, and the countdown system is used.
Use Setting/Procedure
- To clear the count, use [CLEAR DATA] of the Service Mode.
Posted on Nov 20, 2014
  • 225 Answers
SOURCE: konica minolta bizhub 164 showing M2 maintanaince call
You need to replace 1st the consumables before simulation/reset to prevent further damage to Bizhub 164.
Posted on Dec 22, 2014
  • 165 Answers
SOURCE: We have Konica Minolta bizhub 164 copier machine its showing c6101 error code how to resolve that error plz tel me
1 Turn OFF and ON the power switch. 2 Check the connector between M3-MFPB P101 for proper connection and correct as necessary. 3 Check M3 for correct drive coupling and correct as necessary. 4 Check the connector between CIS-MFPB P102 for proper connection and correct as necessary. 5 M3 operation check. 6 Change M3. 7 Change CIS. 8 Change MFPB.
Posted on Sep 15, 2015
  • 102366 Answers
SOURCE: Konica minolta bizhub 164 m2 reset
Do what it says and call service.
Posted on Nov 16, 2016
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
Sep 21, 2014 | Konica Minolta bizhub Office Equipment &...
BIZHUB 164 error M2 what have I to do
Replace the developer and the drum make sure counters are cleared first and that Gradation adj is run along with Toner adj
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 10, 2014 | Konica Minolta PAGEPRO 1380MF All-In-One...
Replace the drum and developer
Jul 10, 2014 | Konica Minolta Office Equipment & Supplies
replace the drum and developer and then reset the counter
Replace the drum and developer, then clear the counter
How to reset m2 error
Have you replace the developer and the drum. First clear the counters for the drum and developer and then replace the drum and developer, then run the required F8. if not the machine will start showing bad copies showing codes. If you clear the counters and don't do anything then the copier will think the parts are new set voltages as required when in fact they are old and will cause problems. So recommend you do the right thing get a tech out to replace the drum and developer
May 19, 2014 | Konica Minolta bizhub C250 All-In-One...
Minolta bizhub 164 code m2
press the Utility button,
then Stop 0 0 Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
Which are very important for copy quality, and not replacing them may cause more harm than good.
May 13, 2014 | Minolta bizhub 200 All-In-One Printer
Konica mintola bizhub 164 maintainace call (M2)
replace the drum and developer and clear the counter also ensure you run the F8 after developer been replaced and new drum are installed
Mar 25, 2014 | Konica Minolta Office Equipment & Supplies
How to solve M2 in bizhub 164
Konika Minolta BizHub 163 - Error Code M2
Press the Utility button,
then Stop 0 0
then press again Stop 0 1
Feb 23, 2014 | Minolta bizhub 200 All-In-One Printer
Reset error m2 in konica minolta 164
Replace the drum and developer first. Resetting counters with out replacing parts is not good. The machine works on base on counter info you reset counters then not replace parts the copier will adjust voltages on certain items when in fact they are same items image problems and codes.
Jan 13, 2014 | Minolta bizhub 180 Black and White Copier
22 people viewed this question
k24674
jasbo
jasbo
