Question about Samsung SCH-u740 Cellular Phone
My Samsung Alias has recently stopped playing 'My music' and the sound in 'My vidoes' but it will play ringtones. Also Whenever I try to call someone or someone calls me my phone says it is connected with the person, but there is no sound. I temporarily fixed the problem a week ago by going to Sound Settings and turning the 'Call Vibrate' to off. But now it goes back to just playing ringtones and nothing else.
My iPhone 5c won't ring
Does the phone plays music without any problem? If you play music to hear it on the loud speaker, and there is no sound, then you probably have a hardware failure, (bad speaker). But if you get to listen to the music, then try this next steps to see if it can be fix.
  • From the iPhone's home screen, tap the Settings app.
  • In Settings, tap Sounds in the third group of options.
  • In Sounds, swipe down to the Sounds and Vibration Patterns section. In that section, look forRingtone. That displays what you have set as your current iPhone ringtone. Tap it to change that.
  • This menu shows you the list of all the ringtones available on your iPhone.
    To get new ringtones, tap the Store button in the top right corner. This will take you to the ringtone section of the iTunes Store where you can stock up on new ringtones.
  • If you choose not to buy new ringtones, but instead use the ones loaded on your phone, the first set of options in the Ringtones section are ones that you bought from the iTunes Store or created using another app and have synced to your iPhone. The ones below the divider came pre-installed on the iPhone.
    Alert Tones, farther down the screen, aren't ringtones exactly. They're alert sounds normally used for alarms and other notifications, but they can be used as ringtones, too.
  • When you tap on a ringtone, it will play so you can preview it and decide if it's what you want. When you've chosen the ringtone you want to use as your default, make sure it has the checkmark next to it. Then tap the Sounds button in the top left corner or click the Home button to go back to the home screen. Your choice is saved automatically.
  • Now, whenever a call comes in, the ringtone you just selected will play (unless you've assigned individual ringtones to callers, that is. If you have, those ringtones take precedence). Just remember to listen for that sound, and not a ringing phone, so you don't miss any calls.
  • Mar 13, 2014 | Cell Phones
    Dear sirs. I hope you can help. I just got the droid HTC EVO. i somehow installed a music video that plays and displays whenever I get a phonecall with this terrible clip of some musician. I desperately...
    here are two ways to setup a ringtone for incoming calls.
    1. From the Home screen tap Settings > Sound & display > Phone ringtone. Tap the ring tone you want to use on the list, and then tap OK.
    2. You can also use a music file as a ringtone. To set up a music file as your ringtone, please use the micro USB cable to connect the phone to a USB port on your computer. The Connect to PC dialog box displays and prompts you to choose Disk drive > Done. Your phone's SD card is mounted as a drive on your computer. You can now copy music files to the SD card.
    After you have finished copying, open the notifications panel (by touching and then dragging the status bar down) on your device; then in the Notifications panel, touch Charge only.
    Then tap All programs > Music > tap the music you want to set as a ringtone (the music will start playing) > press Menu > Set as ringtone. You can set the music file as a Phone ringtone or Contact ringtone or you can select Trim the ringtone.
    Jan 16, 2011 | HTC EVO 4G Smartphone
    Downloading
    Your computer is full of potential free ringtones for your Samsung T229 (also known as Samsung SGH-t229, T-mobile t229) :
    By Bluetooth:
    The Samsung t229 is Bluetooth-enabled. Bluetooth is a wireless system which lets you connect your cell phone to computers, headsets, car kits, etc. If your computer is also Bluetooth-enabled, simply establish a connection between both devices and transfer your music files from your computer to your Samsung t229.
    Simply record sound directly:
    Since your Samsung t229 has a sound recorder (also known as "voice memo"), a very simple technique involves simply placing your phone near your computer's speakers, playing whatever music or sound you would like as a ringtone, and recording it -- you can even use your voice, your child's voice or even your cat's "meow!" Record it with your mobile and there you go! Unless that function was specifically blocked on the Samsung t229, you should be able to navigate to the ringtones section and choose your new recording as a ringtone. Of course, the quality will not be ideal but, after all, it's free!
    Downloading using the phone
    NOTE: MegaTones, HiFi Ringers, and Voices & Sounds are stored at Menu > Fun & Apps > Files > Sounds > Sounds. To download using the phone, perform the following steps: 1. At the main screen, select t-zones. 2. Scroll to and select Music & Sounds. 3. Scroll to and select HiFi Ringers, MegaTones, or Voices & Sounds. 4. Scroll to and select the desired category. 5. Scroll to and select the desired tone. 6. On the preview page, select ACCEPT. 7. After the tone downloads, select Play to preview the tone. 8. Select Set as. 9. Select one of the following options:
    • myFaves ringtone: To set as a myFaves® ringtone. Scroll to and select the desired myFaves contact.
    • Default ringtone: To set as the default ringtone.
    • Caller ringtone: To set as a caller ringtone. Scroll to and select the desired contact.
    • Alarm tone: To set as an alarm tone. Scroll to and select the desired alarm. Turn on the alarm and select the desired time and date.
    10. Select Save.
    Apr 27, 2010 | Samsung SGH-i300 Cellular Phone
    I cant set my sounds as ringtones!!!!!!!
    u set the ringtone from mutimedia>sounds,ussally while playing the will be option "set a ringtone" not from digital audio player,directly from sounds.
    motorola does not accpet viruses infected files or their phone must be trying to send virus attachment or ur phone memory will be full.
    Jul 09, 2009 | Motorola Mobility RAZR V3
    Samsung SHC-U740 Alias resets itself when adding songs to library
    just format the memory card and put songs again on memory card. format with fat format not fat 32.
    Jan 01, 2009 | Verizon Communications Samsung Alias Cell...
    Sound problems
    those symptoms is refered to a cut in a chanel of the flex cable its the part that connects the lcd to the keypad try to replace it
    that will solve the prob 100%
    ps buy a new flex cable dont use the used ones
    Sep 27, 2008 | Samsung SGH-Z500 Cellular Phone
    Music ringtones
    You can't play any ringtones aside the ones that come with the phone or with a software you have to buy. I did not find any software that allowed me to play popular music ring tones. You can download one of these softwares from the palm website and try it for free. The ringtones are similar to what the phone already has, not anything that is playing on the radio
    Jun 25, 2008 | Palm Treo 680 Smartphone
    Samsung SCH-u740 Cellular Phone Logo
    125 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Fotis Papastamatiou
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
