Question about Seiki Televison & Video
My Seiki 46 inch TV has no picture and no sound. The red and blue power light indicator do come on. What should I try to replace first? The mainboard, the power board, or the keyboard indicator board.
    Top Expert:
  • Seiki Master
  • 12,962 Answers
If you have access to a voltmeter and can measure the output voltages from your PS, see if they are within specs. If so then I would say the issue is what is being fed. And the main board deals with both audio and video so I would go that route.
Posted on Apr 29, 2017
  • 1894 Answers
SOURCE: panasonic th-42pa20 plasma 42 inch tv
was that capacitor damaged?
Posted on Jan 11, 2008
  • 927 Answers
SOURCE: DP23 LED not lit on deflection board no picture on tv
Good Day, Gil;
Your problem is in deflection circuit (115+v) check these: FP05, DP15, Q777, QH01, TH01, T701, etc. BUT suspect C707 1k pfd, 2kv, and check all the pico fuses (brown) 2" to the right of cap. Good Luck, big IRISH.
Posted on Sep 01, 2008
SOURCE: Clicking relay no picture no audio no power light red or blue
here is the schematics http://www.scribd.com/doc/33598674/Philips-42mf231d-Chassis-Tpe1-0u-Pa
Posted on Aug 14, 2010
  • 31 Answers
SOURCE: the tv stopped working, stuck
Unfortunately this particular model has a history of bad reports. Often related to plugging a laptop or other device into the VGA connector. If it is under warranty then press them to fix it. If it is not, you are probably better off moving on. Sorry.
Posted on Mar 24, 2011
SOURCE: My LG 37LG50 TV wont turn on ?
Are you certain the replacement power supply is good? A defective main board or power supply can cause this problem.
Posted on May 05, 2013
Seiki TV no picture or sound
hi test the large diodes on the power board these can stop the led from firing up, thanks, ps send me a picture of the power board i'll show you the diodes
shaun
Jun 15, 2017 | Seiki Televison & Video
SEIKI SE50FY28 !! Tv powers on to a blue light but has no picture !!
I would try the TV inputs. Tv/Video or the Source button on your tv remote. Select each input to see if picture comes on. If you have checked all cables and Inputs, I would check the wire from the TV to the cable box.
Jul 30, 2016 | Seiki Televison & Video
Why my SEIKI 50" HD TV turns on indicated by th blue light. Screen is black and no sound. Only about 2 years old.
Do the flashlight test from the video below.
I'm having similar problem, the backlight is not working, I'm trying to find how to replace/repair it.
Aug 02, 2015 | Seiki SE50FY10 50-Inch 1080p 60Hz LED HDTV...
LCD Tv, no picture, no sound, power light only
What have you got? The inverter, the mainboard?
It'll be one or the other...
Jan 31, 2015 | Televison & Video
ELEMENT 46 INCH PICTURE WENT OUT ,SOUND WORKS OK. RED DISPLAY LIGHT IS ON WHEN OFF, BLUE LIGHT WHEN ON
Two bad capacitors in the power supply. it needs to be replaced and the screen will work again.thanks!
Jan 22, 2011 | Televison & Video
No picture or sound/wont power up
Your mainboard is damaged, the mainboard is the one where you plug all the cables (component HDMI), it is really easy to replace, you only need to take special care with the screws.
1. remove all screws in the back.
2. unplugg all cables from mainboard.
3. remove all srews from mainboard and replace it.
4. put all screws back and then plug all cables again.
5. double check all mainboard cables are properly secured.
6. Test TV.
7. put the back cover and secure it with the screws.
8. Enjoy your TV again.
May 30, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Televison & Video Logo
41 people viewed this question
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
shaun taylor
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
