Question about Measuring Tools & Sensors
Setting governor on 18.5 intek v twin - Measuring Tools & Sensors
SOURCE: need pictures of governor springs and governor
model # 12f702-1824e1 mower( that uses weedeater string) had a spring come off the carberator and I don't know where to put it back on.
Posted on Apr 19, 2009
  • 583 Answers
SOURCE: Briggs 20 hp Intek v twin over rev / junk governor
Posted on Sep 21, 2009
  • 21 Answers
SOURCE: replaced coil motor starts and runs at an idle and
could be air cleaner clogged and/or crankcase ventilation
breather or tube to air cleaner frame work clogged
Posted on Sep 26, 2010
  • 3740 Answers
SOURCE: i have a pramac generator
I will respond agan in less than 1 hour with what I can without your Pramac generator model number. I need the model number of the generator to get you the correct answer. In the mean time I will search for what I can find without it and respond ASAP. Expect an answer in less than 1 hour.
Posted on Aug 20, 2011
  • 10 Answers
SOURCE: how to set timing on 23 hp briggs and stratton intek v twin 23 hp
The only way to set the timing is by aligning the cam and crankshaft gears, before doing this check the shear pin in the fly wheel to see if it has been sheared off.
Posted on Oct 31, 2012
Engine rpms is constantly going up and down.
Is the air filter clean?
Governor Ajustment Briggs V-twin - YouTube
? 3:12 26, 2010 - Uploaded by IFIXIT4U The Briggs manual does not do a very good job. You have to adjust the tension on the two springs to set the RPMs that the engine runs at the low and high position. ... I really really need help guys my race motor has a 21hp vtwin brigs, .... Briggs & Stratton opposed twin carburetor series 1 of 3 disassemble ...
Sep 17, 2015 | Briggs & Stratton Briggs Stratton Intek V...
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
For single....the are in 1/2 HP ratings but the link is below....
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Governor does not seem to work
Sometimes the governor gear inside the engine breaks and you have to replace it. Did you try to adjust the governor by putting the throttle full and unloosen the screw on the governor arm and push the governor piece the same direction as the throttle opens and tighten the screw.
Mar 21, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Think i have a problem with governor on my 21hp v-twin briggs. it jumped to max speed and can't get it to slow down. which part of the governoring system could have let go?
Check for a broken spring on the governor linkage, follow your throttle control cable down to where it attaches to the throttle mechanism. In behind where the cable attaches you should be able to see a spring on the governor arm, the spring may have broken or somehow came out of its attaching point. Obviously be very careful about over-revving the engine, it could result in a broken connecting rod and a hole in the side of your crankcase.
Aug 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Intek ohv 19hp V twin modell 407777. Lawn tractor, while mowing, rpms went higher then went full thottle. Throttle level and cable apear to be working fine but the rpms are unefected by it. Visual...
Had the same problem with the same engine. Governor control in the base of the engine fell apart. Requires pulling the engine which is pretty easy, then removing the bolts along the bottom of the crankcase. YOu'll see the governor and or pieces in the bottom. Use a magnet to get all metal pieces from the oil, then replace the governor. Get the model and type off the valve cover from the engine when replacing governor. 3 hour job and you're done..////While it's out check the valve lash by removing rocker covers. Set them at .006 or a tight 007. That way you'll know it didn't through a pushrod when it was over reving..good luck
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
304 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
