Question about The Video Game Consoles & Games
I Iost the game for 2 days, now I have got it back its gone back to chapter 1, can I get it back?
The printer wont printer and displays "Unable to Print. See Troubleshooting and Routine Maintenance Chapter in Users Manual"
Unplug the printer for about 15seconds and then plug back in and power up.......this should reset the error code! Test print and you should be good to go!
Oct 05, 2014 | Brother Mfc9420cn Mfc-9420cn Fax Modem...
How do i remove the passenger airbag from 1997 mazda 626
the fSM is clear, and all cars say the same thing, ALL.
(not details , just in MACRO. )
1: pull battery neg lug.
2: wait 1/2 hour. (so cap.'s can discharge)
3: some FSM have you pull a special yellow plug to make system safe to service, i do recommend reading the FSM , I DO.
or alldata.com same chapter.
4: then gain access to the bag, usually view removed glove box.
im not printing the whole chapter here.
you can log into alldata.com and read as good as me.
and then ask quesions.
above is generic for all bag cars.
they can break your neck, fiddling around , with wires.
think how bags work in a crash and the first microsecond, the car battery is crushed to zero (gone). THE MAGIC of capacitors .
Jun 24, 2014 | 1997 Mazda 626
I have lost the manual and we cannot figure out how to save the game
The only way to save the game is at the end of each chapter in the game. This is done automatically once each chapter is completed. So you have to finish a whole chapter or else you have to do it all over again if you quit the game or turn off the console before finishing the chapter. Sorry.
Feb 28, 2011 | Disney Tangled for Nintendo Wii
How can i unlock all characters in dbz shin budokai another road?
Hello bambamverall
Go throughout story mode (Another Road), to unlock the following characters:
Vegeta (Majin) - Get ending A (can be obtained y not letting enemies destroy any cities in the last chapter).
Picolo (fuse with Kami) - Beat him at the alternate path of chapter 3.
Bardock - Beat him as Goku in chapter 5.
Super Buu with Gotenks absorbed - Finish the 2nd level of chapter 7.
Super Buu with Gohan absorbed - Finish the 3rd level of chapter 7.
Future Gohan - Finish chapter 5.
Dabura - Beat him in the 2nd level in chapter 2.
Cooler (final form) - Complete the 2nd mission in chapter 4.
Hope this helps, good luck!
ajblaj
Sep 10, 2010 | Sony PlayStation Portable (PSP) Console
Im having problems with my playstation 3
error 8001050f this is a bug in the internal clock. just leave your ps3 off for 1-2 days then the problem will fix itself
Mar 03, 2010 | Sony Playstation 3 (PS3) Console
I taped 8 hours of programming in LP mode and want to burn it onto disc. Can I use the divide title mode to split the title into 3 segments so I can fit on 3 discs?
Yes, go into hdd list of recorded shows and select show
edit, chapter mark, find about 1/3 of show, select mark,
yes, back 1 menu under chapter mark is split or cut,
just select and you now have 2 files, 1/3 of show and 1 2/3 of show, just repeat, for 3 parts. and burn to dvd.
Jan 07, 2010 | Philips DVDR3576H DVD Recorder
How to move to next chapter
if its only this game r or l dont work on get a new disk if ots all games get down to the local repair shop (google it if you dont kow where it is) and if they cant fix it, just get a new one
Sep 29, 2009 | Red Mile Entertainment Jackass: The Game...
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
Video Game Consoles & Games Logo
29 people viewed this question
Top The Video Game Consoles & Games Experts
cuberwhite
cuberwhite
Level 1 Expert
Pamela Leach
Pamela Leach
Are you a The Video Game Console and Game Expert? Answer questions, earn points and help others
