How to reset maintenance call (m2) ? - Office Equipment & Supplies
2 Suggested Answers
rajibdip6
  • 23 Answers
SOURCE: proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
THEN CHANGE THE DRUM UNIT OR DEVELOPER
Posted on Dec 15, 2016
How clear Maintenance m2 call service this konica 164
M2 means maintenace time you have to replace 1) developer 2) drum 3) cleaning blade 4) drum charge unit and reset the maintenance counter / calibrate the ATDC. After you than that READY TO COPY will appear ;-)
Oct 17, 2014 | Konica Minolta Office Equipment & Supplies
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
Sep 21, 2014 | Konica Minolta bizhub Office Equipment &...
CAUTION MAINTENANCE CALL (M2) CALL SERVICE
Replace the developer and drum/cleaning blade. Also reset the counters after replacing parts then run F8. resetting the counter with out replacing the above items cause image problems. The copier uses the counters to determine voltages on the drum you tell the copier drum is new and it is still old will cause problems.
Sep 18, 2013 | Minolta bizhub 180 Black and White Copier
Konicaminolta 7216 M2 reset
Resetting the maintenance code display:
1.Entering the Tech.Rep.Mode
Procedure
a) Press the Utility key.
b)Touch Meter Count.
c)Press the following keys in this order : Stop - 0 - 0 -Stop - 0 - 1.
d)Select Tech.Rep.Mode.
2.Resetting the maintenance code:
M2 Waste toner box
Resetting procedure:
a)Enter the Tech.Rep.mode.
b)Select "Counter".
c)Select "Consumables".
d)Select the count of waste toner.
e)Press the clear key.
M3 Oil web roller.
Aug 14, 2012 | Office Equipment & Supplies
M2 error service maintenance
m2 for km 163 or 7216 or equivlent models - it reaches alredy the copy life of the mchine consumbles like drum nd developer, you hve to replce it nd reset the progrms
Oct 05, 2011 | Office Equipment & Supplies
Maintenance M2 call service
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.1-Press utility button on panel.2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.3-its the code to get into service mode.4-After pressing above mentioned buttons you will enter into service mode.5-Now select service choice option.select it by pressing OK button.6-In service choice option you will see Maintenance count option.7-Select it by pressing Yes or OK button.8-There will be three options 0,1,2.9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
Dec 17, 2010 | Minolta bizhub 180 Black and White Copier
Code m2
M2 is a maintenance code, it is usually tied to one of the machines consumable products, drum, developer, or fuser rollers. These items should be checked before attempting to reset the code.
Hope this helps.
Ed
May 11, 2009 | Konica Minolta DiALTA CF910 Copier
Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
k24674
jasbo
jasbo
